[mapserver-users] best practice: map data structure
Steve Lime
Steve.Lime at dnr.state.mn.us
Wed Jul 1 14:41:44 EDT 2009
I believe the include closing problems have long since been resolve. I'm using
22 layer includes in one app with no worries via the CGI. You can always keep
a master mapfile that uses includes and then write a simple script to open that
mapfile and save a production version with all the includes expanded.
Steve
>>> On 6/29/2009 at 1:27 AM, in message
<200906290827.34395.liste at geo-dienstleistung.de>, Frank Broniewski
<liste at geo-dienstleistung.de> wrote:
> Hi Dan,
> thanks for your response. Using includes for the layers is a nice idea, and
> it
> keeps the layer data and configuration together. And you'd get a good
> overview
> over all avail. layers on your server just by looking at the existing.
> directories. Even postgis layers would have a directory since the layers
> mapfile would be stored there. And you could have several "stylesheet" layer
> map files in the directory ...
> And in an application directory you could include all the layers necessary
> for
> the application in a master mapfile.
> Do you have experience in using lots of includes within a mapfile? I
> remember
> using includes for about 30 layers in an php application (pmapper) once
> (v4.10
> on ubuntu 7.10) and I run into problems. namely there where too many open
> files opened by apache and the mapserver process. It seemed, that the
> includes
> weren't closed, and each time the map was redrawn, the includes where opened
> again and so the file system limit of max. open files was reached quite
> soon.
> On Saturday 27 June 2009 17:08:35 Dan Little wrote:
>> It is very dependent on your needs. For example, if you have departments
>> responsible for various layers you may want to divide the structure by
>> that, if there is only one administrator then that isn't necessary.
>> Typically, if there is only one administrator I tend to do something like
>> this...
>> [root]/ -- make this whatever you want and that makes sense from a
>> permissions and storage stand point for your new server.
>> for a simple shapefile layer...
>> [root]/layer_a/layer_a.map
>> [root]/layer_a/layer_a.[shp|dbf|shx]
>> for a tree'd shapfile
>> [root]/layer_b/layer_b.map
>> [root]/layer_b/layer_b.[shp|dbf|shx]
>> [root]/layer_b/data/[... quad tree goes here ...]
>> for a raster...
>> [root]/layer_c/layer_c.map
>> [root]/layer_c/raster/[... raster data ...]
>> Then you can use mapserver includes to include the proper mapfile fragments
>> into an applications various mapfiles.
>> ----- Original Message ----
>> > From: Frank Broniewski <liste at geo-dienstleistung.de>
>> > To: mapserver-users at lists.osgeo.org
>> > Sent: Friday, June 26, 2009 8:43:05 AM
>> > Subject: [mapserver-users] best practice: map data structure
>> > Hello List,
>> > I want to migrate our old server to a new one, and I want to replace the
>> > somewhat grown map data folder and file mess into something more
>> > structured. Therefore I am looking for some advice on how to organize the
>> > Filesystem Hierarchy. Sure somehow its always a matter of taste and need,
>> > but maybe you have some comments on my proposed structure.
>> > I browsed already the mailing list archives and the documentation on the
>> > mapserver site but did not find any related infos, but I am willing to
>> > summarize this thread into a howto document if something useful comes up.
>> > I will be using a linux server, so the structure will reflect the unix
>> > filesystem hierarchy to a certain degree.
>> > A good starting point seems to be /usr/local/ to me.
>> > /usr/local/mapdata/ for storing raster and vector files
>> > /usr/local/mapfiles/ for mapfiles and other config files
>> > You would have /usr/local/mapdata/CLIENTDIR/vector and
>> > /usr/local/mapdata/CLIENTDIR/raster for client specific map data
>> > similar to
>> > /usr/local/mapdata/PROJECTDIR/... for project data
>> > and /usr/local/mapdata/share/vector & /usr/local/mapdata/share/raster for
>> > shared map data (srtm topo maps e.g.)
>> > A good structure for mapfiles & co would be:
>> > /mapfile.map
>> > /fonts/ - font config and font files (ttf)
>> > /icons/ - icon files (png, ...)
>> > /symbols/ - symbol.map
>> > /templates/ - template files
>> > This structure could be mapped to
>> > /usr/local/mapfiles/share/...
>> > or
>> > /usr/local/mapfiles/CLIENTDIR/...
>> > I would really appreciate any comments and shared experience on this ...
>> > Listing:
>> > /usr/local/mapdata/
>> > /usr/local/mapdata/share/raster/
>> > /usr/local/mapdata/share/raster/topo20/
>> > /usr/local/mapdata/share/raster/topo20/01.tif
>> > /usr/local/mapdata/share/raster/topo20/...
>> > /usr/local/mapdata/share/raster/topo20/99.tif
>> > /usr/local/mapdata/share/raster/topo20/tileindex.shp
>> > /usr/local/mapdata/share/vector/
>> > /usr/local/mapdata/share/vector/streetnetwork/
>> > /usr/local/mapdata/share/vector/streetnetwork/streets.shp
>> > /usr/local/mapdata/CLIENT/raster/
>> > /usr/local/mapdata/CLIENT/raster/ortho/
>> > /usr/local/mapdata/CLIENT/raster/ortho/01.tif
>> > /usr/local/mapdata/CLIENT/raster/ortho/...
>> > /usr/local/mapdata/CLIENT/raster/ortho/99.tif
>> > /usr/local/mapdata/CLIENT/raster/ortho/tileindex.shp
>> > /usr/local/mapdata/CLIENT/vector/
>> > /usr/local/mapdata/CLIENT/vector/cad/contours.shp
>> > /usr/local/mapdata/PROJECT/raster/
>> > /usr/local/mapdata/PROJECT/raster/climate/
>> > /usr/local/mapdata/PROJECT/raster/climate/precipitation.tif
>> > /usr/local/mapdata/PROJECT/vector/
>> > /usr/local/mapdata/PROJECT/vector/archeology-sites.shp
>> > /usr/local/mapfiles/share/mapfile.map
>> > /usr/local/mapfiles/share/fonts/
>> > /usr/local/mapfiles/share/icons/
>> > /usr/local/mapfiles/share/symbols/
>> > /usr/local/mapfiles/share/templates/
>> > /usr/local/mapfiles/CLIENT/
>> > /usr/local/mapfiles/CLIENT/mapfile.map
>> > /usr/local/mapfiles/CLIENT/fonts/
>> > /usr/local/mapfiles/CLIENT/icons/
>> > /usr/local/mapfiles/CLIENT/symbols/
>> > /usr/local/mapfiles/CLIENT/templates/
>> > /usr/local/mapfiles/PROJECT/mapfile.map
>> > /usr/local/mapfiles/PROJECT/fonts/
>> > /usr/local/mapfiles/PROJECT/icons/
>> > /usr/local/mapfiles/PROJECT/symbols/
>> > /usr/local/mapfiles/PROJECT/templates/
>> > _______________________________________________
>> > mapserver-users mailing list
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
