[mapserver-users] LABEL_NO_CLIP seems not working in mapserver 5.4.1
Rodriguez, Heraldo hrodriguez at siscat.com.ar
Wed Jul 1 16:30:35 EDT 2009
You are right David ,thanks, I realized the culprit was having set partials=false as I told  Steve in a previous e-mail.
And by the way (Steve and you) it´s Heraldo ( Rodriguez is my surname) ;-)
Lic. Heraldo G. Rodriguez
  TEL: 54-11-4326-4002 int 255
  Dpto. Desarrollo
  Sistemas Catastrales S.A
-----Mensaje original-----
De: David Nugent [mailto:davidn at datalinktech.com.au]
Enviado el: miércoles, 01 de julio de 2009 1:26
Para: Rodriguez, Heraldo
CC: mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] LABEL_NO_CLIP seems not working in mapserver 5.4.1
On 1/7/09 1:02 AM, Rodriguez, Heraldo wrote:
> Hi everyone,
>                We have just upgraded from mapserver 5.2.0 to 5.4.1
> Our application use OpenLayers, Tilecache with metatiles on, and
> postgis.
> The label positioning in polygons has improved a lot but now we are
> experiencing  label duplication on metatile boundaries.
Rodriguez,
I can report having a similar problem, but have noticed that seeems to
be related to use of some of the other settings in the LABEL section. I
don't recall the details exactly unfortunately, but if you are trying to
reproduce a test case then try different values of MINDISTANCE and
POSITION in particular (including AUTO and not present). I know
something I did at some point was causing LABEL_NO_CLIP to not function,
but I don't recall what.
Regards,
David
