[mapserver-users] GetFeatureInfo - something not adding up
Fawcett, David David.Fawcett at state.mn.us
Thu Jul 2 12:10:41 EDT 2009
It may be the case that MapServer isn't recognizing the variables
because they are in the wrong case.  I believe that when the columns
come from a shapefile, the column names are all upper case.  Try
changing all of the substitution vars in your template to upper case.
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of stretch
Sent: Thursday, July 02, 2009 11:03 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] GetFeatureInfo - something not adding up
Hi All
I am doing a GetFeatureInfo Through Openlayers. All seems to be working
fine (i.e. template comes up) except it is not returning any values.
What happens is that template is returned but the values are not
populated - i.e Compt
No: [Compt_No] instead of Compt_no: A03 etc
Here is my URL
http://localhost/cgi-bin/masonite.asp?mf=bartonheights.map&LAYERS=Compar
tments&SERVICE=WMS&VERSION=1.0.0&REQUEST=GetFeatureInfo&STYLES=&EXCEPTIO
NS=application%2Fvnd.ogc.se_xml&FORMAT=png&SRS=EPSG%3A2054&BBOX=-81259.3
86908%2C-3308449.52709%2C-73921.613092%2C-3305902.47291&X=342&Y=226&INFO
_FORMAT=text%2Fhtml&QUERY_LAYERS=Compartments&WIDTH=1040&HEIGHT=361
My Map file (parts of it)
   # WMS server settings
    METADATA
         'wms_title'           'masonite'
         'wms_onlineresource'  'http://zzzzz/masonite.asp?'
	 'wms_srs'             'EPSG:2054'
	  'wms_feature_info_mime_type' 'text/html'
	  'ows_include_items' 'all'
    END
LAYER
    NAME 'Compartments'
    TYPE POLYGON
    DATA 'Farms\BartonHeights\Basedata\Compartments.shp'
	TEMPLATE "Compartments.html"  #For select feature
	TOLERANCE 15
	TOLERANCEUNITS PIXELS
And my Template File
<!-- MapServer Template -->
<TABLE width="98%">
<tr><td>Compartment</td></tr>
<tr><td>Compt No: [Compt_No]</td></tr>
<tr><td>Age: [Age]</td></tr>
<tr><td>Area: [Area_ha]</td></tr>
<tr><td>Species: [Species]</td></tr>
<tr><td>Plant Year: [Pd_yy]</td></tr>
<tr><td>Method: [Method]</td></tr>
</table>
Can anyone see anything drastically wrong. I have copied the template
from a mapserver 5 installation and added the "magic words" at the top -
is there anything else required
Thanks
Andrew
View this message in context:
http://n2.nabble.com/GetFeatureInfo---something-not-adding-up-tp3195907p
3195907.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
