[mapserver-users] GeoJSON output from MapServer
Dejan.Gambin at pula.hr
Thu Jul 2 17:15:41 EDT 2009
Steve,
Is there any GeoJSON example I can see? I must be missing something
trivial,
When I put:
OUTPUTFORMAT
NAME 'geojson'
DRIVER TEMPLATE
MIMETYPE 'application/json; subtype=geojson'
TEMPLATE 'myTemplate.js'
END
in my.map file and call for example
"http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/pmapper/pmapper-3.2.0/config/default/geojson_demo.map&layer=countries"
(this works correctly without geojson part), I get: getString(): Symbol
definition error. Parsing error near (TEMPLATE):(line 74)
If I put DRIVER 'TEMPLATE' then I get: loadOutputFormat(): Unknown
identifier. Parsing error near (TEMPLATE):(line 76)
Finally, putting FORMATOPTION 'FILE=myTemplate.js' instead of TEMPLATE
gives me: loadOutputFormat(): General error message. OUTPUTFORMAT clause
references driver TEMPLATE, but this driver isn't configured.
So, I am obviously doing something wrong regardless the myTemplate.js
file? (anyway, can you give me an example .js file, anything that could
help :-)
regards, dejan
"Steve Lime" <Steve.Lime at dnr.state.mn.us> wrote on 02.07.2009 15:35:28:
> What does myTemplate.js look like?
> >>> <Dejan.Gambin at pula.hr> 07/02/09 5:33 AM >>>
> Thanks Fabio,
> As I said in my last post, I can't get GeoJSON output using this
> outputformat:
> OUTPUTFORMAT
> NAME 'geojson'
> DRIVER 'TEMPLATE'
> END
> regards, dejan
> Fabio D'Ovidio <fabiodovidio at gmail.com> wrote on 02.07.2009 09:28:06:
> > Hi,
> > Dejan.Gambin at pula.hr ha scritto:
> > > Fabio,
> > > Glad to here you are here too :-)
> > > I can certainly use both GeoServer and MapServer but this is not
> > > something I would like at the end. Since I am still investigating
all
> > > this, I am not in such a hurry to get it working with my data ASAP.
> > > So, I would rather go with one of your Mapserver solutions.
> > It is not so difficult...just 2, 3 minutes to load your layer in
> > GeoServer ;-)
> > > My first question, to be sure - so MapOl reads/gets the GeoJSON data
> > > from Geoserver WFS and outputs GeoJSON data to WebClient? If I
> > > understand Steve correctly, there is no way currently to get GeoJSON
> > > output from MapServer WFS, only with CGI? So we come to your
solution
> 2.
> > If you want to use the second solution you must create the HTTP string
> > to get GeoJSON from CGI-MapServer and than you must change MapOl
request
> > to receive data and read them.
> > If you want send me the URL and I'll send you the new MapOl as soon as
> > possbile!
> > Fabio D'Ovidio
> > Geospatial solutions
> > Inova S.r.l.
> > Web : http://www.inovaos.it
> > GeoBI Blog: www.geobi.org
> > Tel.: 081 197 57 600
> > mail: fabiodovidio at gmail.com, f.dovidio at inovaos.it
> > skype: dovidio_fa
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090702/580d7261/attachment.html
