[mapserver-users] point layer symbols
Worth Lutz wal3 at mindspring.com
Mon Jul 6 21:20:00 EDT 2009
Thanks for the help.  The red pixel trick allows me to see the point. It is
in the center of the plane and it looks like I have about a 10 pixel
wingspan for the chosen SIZE 9.
Now my question is about the tolerance.  Does "TOLERANCE 5" mean a 5 pixel
radius or a 5 pixel diameter?
I'm querying with PHP mapscript and expect multiple results in some cases
where items are very close together.  I'm just seeing some multiples where I
do not expect them, but this may be due to the TOLERANCE being set too high.
I'm still playing to get a grip on how this works.
-----Original Message-----
From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Sent: Monday, July 06, 2009 11:48 AM
To: mapserver-users at lists.osgeo.org; Worth Lutz
Subject: Re: [mapserver-users] point layer symbols
Hi Worth: When you define a vector symbol you're essentially defining a
default
size as well (I believe) relative to 0,0. The SIZE you set is then used to
scale the
symbol based on that default size. If things are anchored to 0,0 then it
generally
works ok. I always try to work on the unit square (0,0,1,1) when defining
symbols
although that's not required. Being relative to 0,0 is important.
Anyway, a symbol is always centered on the point. Where the actual point is
depends
on how you laid out the symbol. To see this try adding another styleObj
after your
main symbol like so:
CLASS
    NAME "Major Airport"
    EXPRESSION "MAJOR AIRPORT"
    STYLE
      COLOR 139 0 139
      SYMBOL 'airplane'
      SIZE 9
    END
    STYLE # a red pixel
      COLOR 255 0 0
    END
END
You should see a red pixel over your airplane. That may help explain why you
see the
clicking issues you do. The placement is based on the bounds of the symbol
(0,0,maxx, maxy)
so if a symbol is defined well away from 0,0 then odd things can happen. We
hope to
fix this in upcoming releases.
If you're having trouble with multiple results why not use mode=query
instead of nquery?
Steve
>>> On 7/5/2009 at 4:56 PM, in message
<3684FED92D7A43618E4C56EDCE0ADB93 at Worthlaptop>, "Worth Lutz"
<wal3 at mindspring.com> wrote:
> Can anyone help describe how point symbols defined as type vector are
placed
> upon the point on the map.
> My symbol and layer are listed below.  I get a good looking symbols.
> My problem occurs when clicking on this symbol (and others like a
triangle)
> to query it.
> If I click at the bottom of the airplane, I often get no results.
> If I click above the top of the airplane, I can get results.
> Raising the tolerance causes multiple results when the symbols are close
> together but not touching.
> How is the box surrounding the symbol (the bounds of the symbol) placed
upon
> the point on the map?  And how does size 9 in the class definition relate
to
> the size of this box?  Can anyone shed some light on this for me?
> Thanks,
> Worth
>   SYMBOL
>     NAME 'airplane'
>     TYPE vector
>     POINTS
>     7 0
>     6 1
>     6 3
>     0 4
>     0 6
>     6 5
>     6 8
>     3 8
>     3 9
>     11 9
>     11 8
>     8 8
>     8 5
>     14 6
>     14 4
>     8 3
>     8 1
>     7 0
>     END
>     FILLED TRUE
>   END
> LAYER
>   NAME "airports"
>   STATUS OFF
>   TYPE POINT
>   DATA "air"
>   PROJECTION
>     "init=epsg:32119" # NAD 83 North Carolina (meters US)
>   END
>   MAXSCALEDENOM 3750001
>   TOLERANCE 7
>   CLASSITEM "CLASS"
>   LABELITEM "ARPT_NAME"
>   CLASS
>     COLOR 139 0 139
>     TEMPLATE 'void'
>     SYMBOL 'airplane'
>     SIZE 9
>     LABEL
>       TYPE TRUETYPE
>       MINFEATURESIZE 50
>       MINDISTANCE 150
>       POSITION UC
>       FONT vera
>       SIZE 7
>       #SIZE SMALL
>       COLOR 139 0 139
>     END
>   END
> # ** MORE SIMILAR CLASSES HERE ***
> END
