[mapserver-users] GeoJSON output from MapServer
Dejan.Gambin at pula.hr Dejan.Gambin at pula.hr
Tue Jul 7 02:37:54 EDT 2009
Thanks Steve,
I did all that and I get:
loadOutputFormat(): General error message. OUTPUTFORMAT clause references
driver TEMPLATE, but this driver isn't configured.
Do I have an older MapServer version? Currently, I run this on ms4w 2.2.7
(MapServer 5.0.2), but as I remember, I have also tried with 3.0-beta3
(MapServer 5.4.0) and got the same result.
Does it mean this driver is not supported in those versions?
regards, dejan
mapserver-users-bounces at lists.osgeo.org wrote on 06.07.2009 18:00:03:
> Two things:
> 1) TEMPLATE is a keyword and must be quoted at the moment, so use
> DRIVER 'TEMPLATE'
> 2) The file to be used in the OUTPUTFORMAT is given like this:
>   FORMATOPTION 'FILE=/some/template/file/...'
> 3) You're call to MapServer needs to be a query. For example:
>   http://localhost/cgi-bin/mapserv.exe?
> map=/ms4w/apps/pmapper/pmapper-3.2.0/config/default/geojson_demo.
> map&layer=countries&mode=nquery&qformat=geojson
> This call will use all the default EXTENT value in the mapfile to
> query all eligible layers and run the
> results through the geojson driver.
> I'm doing this to produce javascript code that gets executed by an
> Ext.JS component. Not purely
> GeoJSON but it works similarly.
> Steve
> >>> On 7/2/2009 at 4:15 PM, in message
> <OFA82DFB5F.67E53647-ONC12575E7.0073E271-C12575E7.0074CA4C at pula.hr>,
> <Dejan.Gambin at pula.hr> wrote:
> > Steve,
> > Is there any GeoJSON example I can see? I must be missing something
> > trivial,
> > When I put:
> > OUTPUTFORMAT
> >   NAME 'geojson'
> >   DRIVER TEMPLATE
> >   MIMETYPE 'application/json; subtype=geojson'
> >   TEMPLATE 'myTemplate.js'
> > END
> > in my.map file and call for example
> > "http://localhost/cgi-bin/mapserv.exe?
> > fig/default/geojson_demo.map&layer=countries"
> > (this works correctly without geojson part), I get: getString():
Symbol
> > definition error. Parsing error near (TEMPLATE):(line 74)
> > If I put DRIVER 'TEMPLATE' then I get: loadOutputFormat(): Unknown
> > identifier. Parsing error near (TEMPLATE):(line 76)
> > Finally, putting FORMATOPTION 'FILE=myTemplate.js' instead of TEMPLATE
> > gives me: loadOutputFormat(): General error message. OUTPUTFORMAT
clause
> > references driver TEMPLATE, but this driver isn't configured.
> > So, I am obviously doing something wrong regardless the myTemplate.js
> > file? (anyway, can you give me an example .js file, anything that
could
> > help :-)
> > regards, dejan
> > "Steve Lime" <Steve.Lime at dnr.state.mn.us> wrote on 02.07.2009
15:35:28:
> >> What does myTemplate.js look like?
> >> >>> <Dejan.Gambin at pula.hr> 07/02/09 5:33 AM >>>
> >> Thanks Fabio,
> >> As I said in my last post, I can't get GeoJSON output using this
> >> outputformat:
> >> OUTPUTFORMAT
> >>   NAME 'geojson'
> >>   DRIVER 'TEMPLATE'
> >> END
> >> regards, dejan
> >> Fabio D'Ovidio <fabiodovidio at gmail.com> wrote on 02.07.2009 09:28:06:
> >> > Hi,
> >> > Dejan.Gambin at pula.hr ha scritto:
> >> > > Fabio,
> >> > > Glad to here you are here too :-)
> >> > > I can certainly use both GeoServer and MapServer but this is not
> >> > > something I would like at the end. Since I am still investigating
> > all
> >> > > this, I am not in such a hurry to get it working with my data
ASAP.
> >> > > So, I would rather go with one of your Mapserver solutions.
> >> > It is not so difficult...just 2, 3 minutes to load your layer in
> >> > GeoServer ;-)
> >> > > My first question, to be sure - so MapOl reads/gets the GeoJSON
data
> >> > > from Geoserver WFS and outputs GeoJSON data to WebClient? If I
> >> > > understand Steve correctly, there is no way currently to get
GeoJSON
> >> > > output from MapServer WFS, only with CGI? So we come to your
> > solution
> >> 2.
> >> > If you want to use the second solution you must create the HTTP
string
> >> > to get GeoJSON from CGI-MapServer and than you must change MapOl
> > request
> >> > to receive data and read them.
> >> > If you want send me the URL and I'll send you the new MapOl as soon
as
> >> > possbile!
> >> > Fabio D'Ovidio
> >> > Geospatial solutions
> >> > Inova S.r.l.
> >> > Web : http://www.inovaos.it
> >> > GeoBI Blog: www.geobi.org
> >> > Tel.: 081 197 57 600
> >> > mail: fabiodovidio at gmail.com, f.dovidio at inovaos.it
> >> > skype: dovidio_fa
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090707/261d3fb8/attachment-0001.html
