[mapserver-users] analysis web using Map Server
Gito Ginting
gito_kribo at yahoo.com
Tue Jul 7 06:13:33 EDT 2009
Dear Till
Thank you for your explanation, my friend alredy told me that I suppose to used a GRASS.
But there's another question that being my thought,
first, the scripts to connect between mapserver and the GRASS software
second, how to interpolate the data [in this case I use Rainfall data]
in GRASS then mapserver shows the interpolation result from GRASS in
mapserver?
I am loooking for ur advice
best,
Gito
--- On Tue, 7/7/09, Till Adams <adams at terrestris.de> wrote:
Subject: Re: [mapserver-users] analysis web using Map Server
To: "Gito Ginting" <gito_kribo at yahoo.com>, "mapserver" <mapserver-users at lists.osgeo.org>
Date: Tuesday, July 7, 2009, 4:23 PM
Dear Gito,
UMN is not a real "GIS application" itsself, UMN is more capable for showing processed GIS data in the internet. There are some possibilities to interact with PostGIS, but if you really want to interpolate data from points to surfaces, you should think about using a GIS in your backend (e.g. GRASS, which supports a PHP, python (and some others based) interface to web-applications).
As an example we use GRASS as backend so that users may interpolate time-series of measured soil-moisture data and present this data via UMN Mapserver in an OpenLayers based client.
So, what you need is an architecture, not purely UMN.
Correct me, if I'm wrong... -)
Hope this points you in a direction
Till
> Hi all,
> I am just introduced to Map Server, I've developed a web server with Fedora 7 and would like to develop a tool for map analysis in web by using Map Server.. Advise please, how to make a map interpolation with Map Server? and also the requirement for developing the interpolation?
> Thanks
> Gito Ginting
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090707/5d9639da/attachment.html
