[mapserver-users] problem with connection to oracle
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Tue Jul 7 11:14:28 EDT 2009
This means that you have not compiled MapServer with support for Oracle Spatial. Are you using a binary distribution, if so you'll need to compile from source and include that path to your local Oracle Client install. What OS are you running under?
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of youness.elmedraoui at somei.fr
Sent: Tuesday, July 07, 2009 11:11 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] problem with connection to oracle
Hello,
I have a problem with oracle connection.
I use this script:
LAYER
CONNECTIONTYPE oraclespatial
CONNECTION ".../... at ..."
END
and I have these errors for:
- oraclespatial:
msDrawMap(): Image handling error. Failed to draw layer named .... msOracleSpatialLayerOpen(): OracleSpatial error. OracleSpatial is not supported .
Can you help me plz? thanks
Best Regards
Youness ELMEDRAOUI
Les informations figurant sur cet e-mail ont un caractère strictement confidentiel et sont exclusivement adressées au destinataire mentionné ci-dessus.Tout usage, reproduction ou divulgation de cet e-mail est strictement interdit si vous n'en êtes pas le destinataire.Dans ce cas, veuillez nous en avertir immédiatement par la même voie et détruire l'original. Merci
