[mapserver-users] Object reference not set to an instance of an
object
Suman Chatterjee
schatterjee at addisontx.gov
Thu Jul 9 10:49:52 EDT 2009
I corrected my problem. Actually, I changed the code a little bit.
Const string MAP_FILE = "c:/inetpub/wwwroot/Addison.map"
Map= new mapObj(MAP_FILE)
The line
System.Configuration.ConfigurationManager.AppSettings["C:/ms4w/Apache/ht
docs/mapservertest/Addison.map"]
Is throwing error. No idea what it is trying to do.
Now my application is working fine in IIS and C#.
Suman
-----Original Message-----
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Wednesday, July 08, 2009 6:22 PM
To: Suman Chatterjee
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Object reference not set to an instance
of an object
Hi Suman,
I suspect
docs/mapservertest/Addison.map"] evaluates to null in your case, and
therefore the ToString() operation on the null reference is failing
which problem is not related to the MapScript library itself.
Best regards,
Tamas
2009/7/8 Suman Chatterjee <schatterjee at addisontx.gov>
Hi all,
I am trying to develop an application in C# (VS2005) with mapscript. I
saw the material of Paolo. But I am facing a problem
In the line
mapObj map= new
mapObj(System.Configuration.ConfigurationManager.AppSettings["C:/ms4w/Ap
ache/htdocs/mapservertest/Addison.map"].toString())
It is generating the error " Object reference not set to an instance of
an object"
How can I correct this? If anyone helps me in correcting it, it will be
great.
Suman
This e-mail and any files or attachments transmitted with it contains
Information that is confidential and privileged. This document may
contain Protected Health Information (PHI) or other information that is
intended only for the use of the individual(s) and entity(ies) to whom
it is addressed. If you are the intended recipient, further disclosures
are prohibited without proper authorization. If you are not the intended
recipient, any disclosure, copying, printing, or use of this information
is strictly prohibited and possibly a violation of federal or state law
and regulations. If you have received this information in error, please
delete it and notify Hamid Khaleghipour at 972-450-2868 immediately.
Thank you.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
This e-mail and any files or attachments transmitted with it contains Information that is confidential and privileged. This document may contain Protected Health Information (PHI) or other information that is intended only for the use of the individual(s) and entity(ies) to whom it is addressed. If you are the intended recipient, further disclosures are prohibited without proper authorization. If you are not the intended recipient, any disclosure, copying, printing, or use of this information is strictly prohibited and possibly a violation of federal or state law and regulations. If you have received this information in error, please delete it and notify Hamid Khaleghipour at 972-450-2868 immediately. Thank you.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090709/d8900108/attachment.html
