[mapserver-users] mapserver or MS4W package on Windows x64
Tamas Szekeres
szekerest at gmail.com
Thu Jul 9 11:10:33 EDT 2009
2009/7/9 John Callahan <john.callahan at udel.edu>
> I started working with the x64 binaries from Tamas' site at
> http://vbkto.dyndns.org:1280/sdk/Default.aspx. MSVC2005 (Win64) seemed
> most appropriate for me. However, I did not see php mapscript support. Is
> that true? I did see mapscript for java, python, and csharp.
> Can php mapscript run at all with x64 versions of Apache/PHP and/or
> Mapserver? If not, then I'll have to give up x64 or PHP. Bummer.
Hi John,
PHP support is lacking at the moment. I think if libphp could be compiled
for x64 then it wouldn't be a problem to compile php mapscript against it.
I'll give it a try this weekend if I have enough time.
> I've also been reading that I should run Mapserver in fastcgi mode, in
> either Win32 or Win64 versions. Does that mean to use PHP mapscript that I
> need to run PHP in cgi/fastcgi mode and NOT as an apache module?
I think that's not a strong requirement, you could either use fastcgi and
cgi equally well, however fastcgi will perform better.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090709/233cfba3/attachment.html
