[mapserver-users] Backgrounds and Graticules in Pseudo-cylindrical Projections
winwaed at gmail.com winwaed at gmail.com
Tue Jul 14 08:42:56 EDT 2009
I am using MapServer to create some web maps using equal area projections.
Most of these are pseudo-cylindrical, and I am currently using Mollweide
for the initial development.
This works fine and I even have it working with WMS to OpenLayers
(OpenLayers and adding layers from different projections is a different
kettle of fish, but I've asked that question elsewhere!).
With a projection like this, a zoomed out map has two areas: projected
space, and non-projected space. Ie. the projected globe does not take up
the entire map "canvas".
To me, this means we have two background colors: the background for the
shapes in projected space, and the true background of non-projected space.
I hope that makes sense?
I'll try with a real world example. I have a layer that shows land masses.
This is green. The mapfile is set to have a blue background (for the
oceans). These are being drawn correctly, but the blue is also used for
areas outside the projected globe.
Is it possible to specify a different color (or "transparent") for the area
outside the projected globe?
The best idea I have is that I create a new layer of three shapes that
cover the entire globe completely. This would be drawn as blue as the
lowest layer in the mapfile, and the mapfile's background would be set to
white. Is there a more efficient way?
I would also like to add a geographic graticule (ie. meridians and
parallels). I've tried the GRID definition in the mapserver map file, but
this simply draws a cartesian grid in projected space. Can this be done in
MapServer? I guess I could again solve this with a new layer of shapes.
Otherwise it is OpenLayers (with a dev version of a graticule control, or
more likely - write my own code)
Richard Marsden
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090714/f31f24c5/attachment.html
