[mapserver-users] Performance in regular expressions or an
alternative way to select a list of features
Adrian Popa
adrian_gh.popa at romtelecom.ro
Wed Jul 15 02:09:00 EDT 2009
Hello David,
I wasn't aware of the "IN" syntax. It looks cleaner, and hopefully will
be better. I think in the end I will try all sollutions and see which
one is the fastest for a given (large) expression.
Thangs again,
Adrian
Fawcett, David wrote:
> Adrian,
> One method that I have used is to use an IN statement in my expression
> and then use a variable to populate the list of IDs in the statement.
> I create a class like this:
> CLASS
> NAME "Low"
> EXPRESSION ('[COUNTY_FIP]' in '%group1%')
> OUTLINECOLOR 0 0 0
> COLOR 255 204 204
> END
> And then in the URL calling the map, I include &group1=27001,27003,27005
> I actually use this with five classes (five different URL vars) to
> create a thematic map of counties based entirely on data passed in
> through the URL.
> I have no idea on how the performance of this method compares to what
> you have done, but it might be worth a try. There are only 87
> counties in Minnesota, so that is the largest number it gets, but the
> performance isn't bad.
> David.
> -----Original Message-----
> *From:* mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of
> *Adrian Popa
> *Sent:* Tuesday, July 14, 2009 1:15 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Performance in regular expressions or
> an alternative way to select a list of features
> Hello everyone,
> Here's my problem: I'm trying to highlight segments from a line
> layer by using an expression in a specific class. This portion of
> the mapfile is dynamically generated and when it is done, it is
> sent to mapserver for rendering.
> My problem is that I have to select between 10 - 400 features at a
> time and I noticed when I have a lot of features there is a severe
> performance degradation in mapserver (takes a lot of time to
> render or even times out).
> Right now, my expression is built using regular expressions:
> something like:
> *EXPRESSION /^ITEM1$|^ITEM2$|^ITEM3$|^ITEM4$/*
> This works ok, but as I said has a performance penalty when you
> reach ~400 items. My data is selected from a shapefile layer
> which has about 5500 items.
> Since I wouldn't be using the regular expressions at full capacity
> (I'm matching the full name), I might rewrite the expression using
> something like:
> *EXPRESSION ( ([NAME]=="ITEM1") OR ([NAME]=="ITEM2") OR
> ([NAME]=="ITEM3") OR ([NAME]=="ITEM4") )*
> From the documentation I see that:
> /Regular expression with MapServer work similarly to string
> comparison, but allow more complex operation. They are slower than
> pure string comparisons, but might be still faster than logical
> expression. As with the string comparison use regular expressions,
> a FILTERITEM or a CLASSITEM has to defined, respectively.
> /I would like to know if there is an efficient way of selecting a
> list of elements from a layer, or what are your recommendations.
> Also - have there been significant changes in performance for this
> issue from mapserver 4.10 (I am now migrating to mapserver 5.4)?
> Thanks,
> Adrian
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090715/49ee9b51/attachment.html
