[mapserver-users] Mapfile displaying in red
Paul Curran
paul_everton at hotmail.com
Wed Jul 15 06:19:41 EDT 2009
Hi
When i load my map file which can be seen below i can view the outline of map but the actual map displays as red. I am viewing the map via the mapserver.exe (e.g.http://localhost/cgi-bin/mapserv.exe?mode=map&map=c:/ms4w/apps/openlayers-2.5/data/test.map&layer='map')
Here is my map file, Can anyone spot were i am going wrong? any help greatly appreciated.
The uk.shp file i am attempting to load consists of .tiff images amd was put together using FWTools
MAP
NAME test
# Map image size
SIZE 400 600
IMAGECOLOR 249 245 186
IMAGETYPE PNG24
OUTPUTFORMAT
NAME PNG24
DRIVER 'GD/PNG'
MIMETYPE 'image/PNG'
#IMAGEMODE PC256
EXTENSION 'png'
END
EXTENT -888385.321101 -31000.000000 1548385.321101 1271000.000000
WEB
IMAGEPATH "\ms4w\tmp\ms_tmp\"
IMAGEURL "\ms_tmp\"
METADATA
WMS_SRS "EPSG:4326 EPSG:900913"
END
END
LAYER
NAME 'map'
DATA 'C:\ms4w\apps\openlayers-2.5\data\map.shp'
TYPE polygon
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'map'
STYLE
COLOR 255 0 0
END
LABEL
TYPE bitmap
END
END
END
END
_________________________________________________________________
Get the best of MSN on your mobile
http://clk.atdmt.com/UKM/go/147991039/direct/01/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090715/857a8498/attachment.html
