[mapserver-users] Building Mapserver with Mapscript and AGG
Jason Beverage
jasonbeverage at gmail.com
Thu Jul 16 13:26:37 EDT 2009
Hi Nick,
I've also tried AGG 2.5 and get the same result. I can build it just fine,
its just that the Python bindings don't work correctly.
Thanks,
Jason
On Thu, Jul 16, 2009 at 1:14 PM, Nikolai Nikolov <nnikolov at gypsii.com>wrote:
> Hi Jason,
> Mapserver 5.2.0 and later versions build successfully with AGG 2.5 !!! So
> I would suggest, as the best option for you, to get AGG 2.5 and then build
> AGG and Mapserver.
> Best regards,
> Nick
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Jason Beverage
> *Sent:* 16 July 2009 18:08
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Building Mapserver with Mapscript and AGG
> Hi all,
> I'm trying to build Mapserver 5.4.1 against AGG 2.4 with Python Mapscript
> on Centos 5 and I'm having some trouble.
> I followed the instructions on http://mapserver.org/installation/unix.htmland modified the Makefile.in.Linux of AGG to include the -fPIC option to
> support mapscript. AGG seems to build libagg.a just fine in the src
> directory.
> When I build mapserver against that version of AGG, it compiles fine and so
> do the python bindings. However, when I install and try to use mapscript in
> python, I get an error when I try to import the mapscript module:
> ImportError: /usr/lib/python2.4/site-packages/_mapscript.so: undefined
> symbol: _ZN3agg12g_sqrt_tableE
> This appears to be an error due to the -fPIC option not being specified in
> the AGG build, which I've done.
> Are there any other steps that must be done to successfully compile
> Mapserver against AGG to get the python bindings to work?
> Thanks,
> Jason
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090716/84a9c3ec/attachment.html
