[mapserver-users] Building Mapserver with Mapscript and AGG
Jason Beverage
jasonbeverage at gmail.com
Thu Jul 16 13:44:13 EDT 2009
Hi Andy,
I tried modifying both the Makefile.in.Linux as well as the regular
makefile. I can see -fPIC on the command line, so it appears to be doing
what I want, but I still get the same error in both cases.
Jason
On Thu, Jul 16, 2009 at 1:32 PM, Andy Colson <andy at squeakycode.net> wrote:
> Jason Beverage wrote:
>> Hi Nick,
>> I've also tried AGG 2.5 and get the same result. I can build it just
>> fine, its just that the Python bindings don't work correctly.
>> Thanks,
>> Jason
>> On Thu, Jul 16, 2009 at 1:14 PM, Nikolai Nikolov <nnikolov at gypsii.com<mailto:
>> nnikolov at gypsii.com>> wrote:
>> Hi Jason,
>> Mapserver 5.2.0 and later versions build successfully with AGG 2.5
>> !!! So I would suggest, as the best option for you, to get AGG 2.5
>> and then build AGG and Mapserver.
>> Best regards,
>> Nick
>> *From:* mapserver-users-bounces at lists.osgeo.org
>> <mailto:mapserver-users-bounces at lists.osgeo.org>
>> [mailto:mapserver-users-bounces at lists.osgeo.org
>> <mailto:mapserver-users-bounces at lists.osgeo.org>] *On Behalf Of
>> *Jason Beverage
>> *Sent:* 16 July 2009 18:08
>> *To:* mapserver-users at lists.osgeo.org
>> <mailto:mapserver-users at lists.osgeo.org>
>> *Subject:* [mapserver-users] Building Mapserver with Mapscript and AGG
>> Hi all,
>> I'm trying to build Mapserver 5.4.1 against AGG 2.4 with Python
>> Mapscript on Centos 5 and I'm having some trouble.
>> I followed the instructions on
>> http://mapserver.org/installation/unix.html and modified the
>> Makefile.in.Linux of AGG to include the -fPIC option to support
>> mapscript. AGG seems to build libagg.a just fine in the src directory.
>> When I build mapserver against that version of AGG, it compiles fine
>> and so do the python bindings. However, when I install and try to
>> use mapscript in python, I get an error when I try to import the
>> mapscript module:
>> ImportError: /usr/lib/python2.4/site-packages/_mapscript.so:
>> undefined symbol: _ZN3agg12g_sqrt_tableE
>> This appears to be an error due to the -fPIC option not being
>> specified in the AGG build, which I've done.
>> Are there any other steps that must be done to successfully compile
>> Mapserver against AGG to get the python bindings to work?
>> Thanks,
>> Jason
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> When you do a make, if you scroll back up into the output do you see -fpic
> on the command line?
> You say you modified Makefile.in.Linux? Do you use the automake stuff?
> I didnt, I used the normal Makefile, which includes src/Makefile. I
> modified src/Makefile and changed:
> CXXFLAGS= $(AGGCXXFLAGS) -I../include -L./
> to
> CXXFLAGS= $(AGGCXXFLAGS) -fPIC -I../include -L./
> and then just did:
> make
> -Andy
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090716/03b3a65b/attachment-0001.html
