[mapserver-users] Building Mapserver with Mapscript and AGG
Thomas Bonfort thomas.bonfort at camptocamp.com
Thu Jul 16 14:25:44 EDT 2009
Yes, version 5.6 or 6.0, whatever it's called, will include the agg
tree, in a hope to cut down on the multiple problems that folks were
having with compiling agg correctly. you can already try it out by
using a trunk version of mapserver and report back to us if any
problems arise.
regards,
thomas
www.camptocamp.com
+33 4 79 26 57 97
On Thu, Jul 16, 2009 at 19:55, Jason Beverage<jasonbeverage at gmail.com> wrote:
> Nick,
> Thanks for your suggestion of updating to AGG 2.5 from rpm forge!  Doing so
> gave me a nice shared library of AGG and I've got my mapscript Python
> working now, thanks!
> From what I've been reading on the mailing list, there are talks of just
> including AGG directly into the Mapserver source, which would be wonderful.
> The less dependencies the better :)
> Thanks again!
> Jason
> On Thu, Jul 16, 2009 at 1:49 PM, Andy Colson <andy at squeakycode.net> wrote:
>> Jason Beverage wrote:
>>> Hi Andy,
>>> I tried modifying both the Makefile.in.Linux as well as the regular
>>> makefile.  I can see -fPIC on the command line, so it appears to be doing
>>> what I want, but I still get the same error in both cases.
>>> Jason
>> Did you build mapserver with agg first, before mapscript?  I'm using the
>> perl stuff, but saw a similar error.  I went back and did a 'make clean' and
>> make for each of agg, mapserver and then mapscript/perl.  (in that order)
>> Otherwise, I'm afraid I dunno...
>> -Andy
> mapserver-users at lists.osgeo.org
