[mapserver-users] Scaling Image Symbol Offset
David Martin
David at itbeyond.com.au
Thu Jul 16 20:24:24 EDT 2009
I am developing a new application and am rendering around a load of
graphic symbol layers using a Map file layer such as
LAYER
NAME cape_headland_point
STATUS ON
GROUP all
DATA 'ExplorOz/Places/Cape,Headland,Point'
TYPE POINT
SYMBOLSCALE 1000000
CLASS
STYLE
SYMBOL [POIImage]
MAXSIZE 15
MINSIZE 4
SIZE 8
END
END
METADATA
"wms_title" "Capes, Headlands & Points"
END
PROJECTION
"+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +no_defs"
END
END
As you can see I am sizing the output symbol which is a 20x20px PIXMAP
image - this is working great however the position of the image needs to
be OFFSET up by half the size of the image (to make the actual point be
the center of the image) - I have tried using OFFSET however when the
image size changes (based on SYMBOLSCALE)the offsets are wrong. Is there
a way to OFFSET image symbols based on the SYMBOLSCALE and MAX/MIN
SIZES?
Regards
David
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090717/86197aa3/attachment.html
