[mapserver-users] Scaling Image Symbol Offset
Havard Tveite
havard.tveite at umb.no
Fri Jul 17 04:50:13 EDT 2009
RFC 45 suggests several rendering improvements for Mapserver,
including adding a tag (CENTER/ORIGIN) for specifying the
centre of a symbol. This feature has, however, not been
given priority yet (there are workarounds for the most
important cases).
http://mapserver.org/development/rfc/ms-rfc-45.html
CENTER/ORIGIN [x y]
Defines the centre of the symbol using decimal pixels (x axis increasing to the right, y axis increasing downwards).
* Is used for placing a point symbol on the map or on a “decorated” line
* Defines the center of rotation if an ANGLE is specified for point symbols.
* Default value is the centre of the symbol’s bounding box.
* Applies to TYPE ellipse, vector, pixmap, truetype.
Håvard
David Martin wrote:
> I am developing a new application and am rendering around a load of
> graphic symbol layers using a Map file layer such as
> LAYER
> NAME cape_headland_point
> STATUS ON
> GROUP all
> DATA 'ExplorOz/Places/Cape,Headland,Point'
> TYPE POINT
> SYMBOLSCALE 1000000
> CLASS
> STYLE
> SYMBOL [POIImage]
> MAXSIZE 15
> MINSIZE 4
> SIZE 8
> END
> END
> METADATA
> "wms_title" "Capes, Headlands & Points"
> END
> PROJECTION
> "+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +no_defs"
> END
> END
> As you can see I am sizing the output symbol which is a 20x20px PIXMAP
> image – this is working great however the position of the image needs to
> be OFFSET up by half the size of the image (to make the actual point be
> the center of the image) – I have tried using OFFSET however when the
> image size changes (based on SYMBOLSCALE)the offsets are wrong. Is there
> a way to OFFSET image symbols based on the SYMBOLSCALE and MAX/MIN SIZES?
> Regards
> David
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
