[mapserver-users] Changing to Layers.WMS from Layers.Mapserver
bartvde at osgis.nl bartvde at osgis.nl
Fri Jul 17 07:22:04 EDT 2009
there are several things wrong here.
'wms_srs' "epsg: 32119 epsg: 4326"
should be (uppercase EPSG for METADATA and no space in between):
'wms_srs' "EPSG:32119 EPSG:4326"
however Mapserver cannot reproject your data if you do not add a
PROJECTION block to your LAYER stating the projection in which your data
resides.
Also, in OpenLayers the syntax is (your map can only be in 1 projection):
{projection: "EPSG:32119"}
Best regards,
Bart
> Hi, i am having trouble trying to display my map in Open Layers via
> OpenLayers.Layer.wms.
> Firstly I Built a shape file of the UK as a raster tileindex. I can now
> view my map via "//localhost/cgi-bin/mapserv.exe/mymapfile.map" and the
> map looks fine.
> I am now trying to view my map via OpenLayers. Firstly I used
> Openlayers.Layer.MapServer which displayed my map however zoomed in very
> close. However I have read Layer.Mapserver should be avoided and Layer.WMS
> should be used instead.
> I attempted to amend both my map and openlayers files to display via WMS
> by
> Including:
> METADATA
>       ‘wms_srs’ “EPSG: 32119 EPSG: 4326”
> END
>  within the WEB section of my map file and adding OpenLayers.WMS within my
> OpenLayers file.
> However I now get the following error message within the openlayers map
> window “msWMSLoadGetMapParams(): WMS Server Error”
> I also added ‘projection: "epsg: 32119 epsg:4326” into my openlayers file
> which hasn’t made any difference
> Does anyone have any idea where I am going wrong? Any help greatly
> appreciated. My map and openlayers files are below.
> Cheers
> p.s. I ahve installed ms4w on windows which i tihnk supports WMS
> MAP
>     NAME UK1
>     SIZE 1600 1200
>     IMAGECOLOR  153 204 255
>     IMAGETYPE JPEG
>     SHAPEPATH "http://localhost/openlayers/data/"
>     EXTENT  -888385.321101 -31000.000000 1548385.321101 1271000.000000
>     UNITS METERS
>       WEB
>               TEMPLATE "http://localhost/openlayers/examples/test.html"
>               LOG "\ms4w\tmp\ms_tmp\log.txt"
>       IMAGEPATH "\ms4w\tmp\ms_tmp\"
>       IMAGEURL "/ms_tmp/"
>       METADATA
>       END
>             END
>   LAYER
>                NAME "UK"
>                STATUS DEFAULT
>                TYPE raster
>                TILEINDEX "map"
>                TILEITEM "Location"
>                CLASS
>                  STYLE
>                   COLOR 0 0 0
>                  END
>                  LABEL
>                   COLOR 0 0 0
>                   SIZE SMALL
>                  END
>               END
>   END
> END
> <html xmlns="http://www.w3.org/1999/xhtml">
>   <head>NARIMS MAPPING TEST
>     <style type="text/css">
>         #map {
>             width: 95%;
>             height: 95%;
>             border: 10px solid black;
>     </style>
>     <script src="../lib/OpenLayers.js"></script>
>     <script type="text/javascript">
>       var zoom = 1;
>       var bounds = new OpenLayers.Bounds(-888385.321101, -31000.000000,
> 1548385.321101, 1271000.000000);
>       var map, layer;
>       function init(){
>       map = new OpenLayers.Map('map', { maxExtent: bounds });
>       map.addControl(new OpenLayers.Control.PanZoomBar());
>       map.addControl(new OpenLayers.Control.OverviewMap());
>       map.addControl(new OpenLayers.Control.MousePosition());
>       layer = new OpenLayers.Layer.WMS ( "OpenLayers WMS",
>       "http://127.0.0.1/cgi-bin/mapserv.exe?", { layers: 'basic', map:
> '/ms4w/apps/openlayers-2.5/data/uk1.map', projection: "epsg “32119
> epsg:4326" },
>       { gutter: 15 });
>       map.addLayer(layer);
>       map.zoomToExtent(bounds);
>       map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
>     </script>
>   </head>
>   <body onload="init()">
>     <div id="map"></div>
>   </body>
> </html>
> _________________________________________________________________
> Share your photos with Windows Live Photos – Free.
> http://clk.atdmt.com/UKM/go/134665338/direct/01/_______________________________________________
> mapserver-users at lists.osgeo.org
