[mapserver-users] duplicate labels
Lars Lingner
ml at lingner.eu
Fri Jul 17 15:25:48 EDT 2009
Andy Colson schrieb:
>>> Hi All,
>>> Here is a screen shot:
>>> http://maps.camavision.com/map.jpg
>>> There are, as far as I can tell, 4 lines. The label is duplicating and
>>> I dont want it too. Here is the layer from the mapfile:
>>> LAYER
>>> NAME annotate_pin
>>> TYPE line
>>> STATUS on
>>> CLASS
>>> NAME "HIGHLIGHT"
>>> STYLE
>>> COLOR 0 255 0
>>> OUTLINECOLOR 0 255 0
>>> WIDTH 3
>>> END
>>> LABEL
>>> TYPE truetype
>>> FONT "Vera"
>>> SIZE 10
>>> COLOR 0 0 0
>>> ANGLE follow
>>> POSITION auto
>>> BACKGROUNDCOLOR 255 255 255
>>> MINDISTANCE 900
>>> END
>>> END
>>> END
>>> I have played with MINDISTANCE from 0 to 99,000 and it does not seem to
>>> make a difference. I googled a little but have not found a useful
>>> answer.
>> If you want to use MINDISTANCE you have to set the SIZEUNITS parameter
>> at layer level like this:
>> LAYER
>> SIZEUNITS meters # one of [pixels|feet|inches|kilometers|meters|miles]
>> LABEL
>> MINDISTANCE 500
>> END
>> END
>> So the label wouldn't repeated for distances smaller than 500 meter.
>> Lars
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> That didn't seem to work. It made all my fonts really small, but the
> labels still duped.
Do you have at MAP level the UNITS parameter?
[feet|inches|kilometers|meters|miles|dd]
Please try that, I should have told you that in my last reply ;)
also: which projection have you set at MAP level?
> The help says layer.sizeUnits "Sets the unit of CLASS object SIZE", does
> that include label font size?
it sets the unit of the object size, not the size itself. The font size
is controlled by the SIZE parameter (LABEL object)
> It defaults to pixels, yes? Wouldnt a really big MINDISTANCE still have
> removed dups?
Not necessarily... Often they are different in orders of magnitude
Lars
