AW: [mapserver-users] openlayers/mapserver
Arnd Wippermann
arnd.wippermann at web.de
Fri Jul 17 15:47:40 EDT 2009
with a right click on the pink tile you can get the url of the image. Test
it in the browser and you should get an error message.
Perhaps it's the wrong parameter SRS (it's a wms parameter) or the absent
parameter map_projection (mapserver parameter).
You should also declare options for your map object. I think by default
OpenLayers uses EPSG:4326 with the extent -180,-90,180,90.
Arnd
_____
Von: mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von YOUNESS
ELMEDRAOUI
Gesendet: Freitag, 17. Juli 2009 13:06
An: mapserver-users at lists.osgeo.org
Betreff: [mapserver-users] openlayers/mapserver
i created my wms server and i test them with a GetCapabilities and GetMap
REQUEST :
http://localhost:81/cgi-bin/mapserv.exe?map=C:/OLWebSite/App_Data/olvbmapfil
el.map
<http://localhost:81/cgi-bin/mapserv.exe?map=C:/OLWebSite/App_Data/olvbmapfi
lel.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSiON=1.1.0>
el.map
lel.map&REQUEST=GetMap&SERVICE=WMS&VERSiON=1.1.0&Layers=compfun,zone&SRS=EPS
G:32632&STYLE=&BBox=1143759,4417539,1146436,4420390&FORMAT=image/png&WIDTH=4
00&HEIGHT=400>
&REQUEST=GetMap&SERVICE=WMS&VERSiON=1.1.0&Layers=compfun,zone&SRS=EPSG:32632
&STYLE=&BBox=1143759,4417539,1146436,4420390&FORMAT=image/png&WIDTH=400&HEIG
HT=400
and my tests is ok.
now, i want to displat data with openlayers.
i tested this code but it doesn't work.
map = new OpenLayers.Map( 'map' );
layer = new OpenLayers.Layer.MapServer("ol demo",
"http://localhost:81/cgi-bin/mapserv.exe?map=C:\OLWebSite\App_Data\olvbmapfi
lel.map&", {Layers:'compfun',SRS:'EPSG:32632'} );
see result in attachement.
can any one help me plz?
do you have an exemple for displayind data with openlayers based on mapfile?
Best regards,
Youness ELMEDRAOUI
Les informations figurant sur cet e-mail ont un caractère strictement
confidentiel et sont exclusivement adressées au destinataire mentionné
ci-dessus.Tout usage, reproduction ou divulgation de cet e-mail est
strictement interdit si vous n'en êtes pas le destinataire.Dans ce cas,
veuillez nous en avertir immédiatement par la même voie et détruire
l'original. Merci
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090717/5abe9f4f/attachment-0001.html
