[mapserver-users] Error running ./configure on a Linux machine
Michalis Avraam michalis at u.washington.edu
Fri Jul 17 18:00:46 EDT 2009
Hello all.
 I have tried to compile MapServer 5.4.1 for the last few hours to no
 avail. I cannot get past the ./configure command for some reason. Any
 input will be greatly appreciated.
 Basically, my problem is that ./configure refuses to recognize some of
 the commands I give it for some reason (for example, --with-agg or
 --with-png). It also refuses to find files on the system when I
 specify paths. For example, /usr/sbin/httpd or /usr/bin/xml2-config. I
 have made sure that the files are there, installed correctly, running
 just fine and are accessible by the user running ./configure.
 Any ideas what might be the problem? The following information may be useful.
 Thank you in advance,
 Michalis
 Environment:
 Fedora Core 11 x86
 Intel Core2Duo
 2GB Ram
 Configure script run:
 ./configure --enable-debug              \
            --with-freetype=/usr        \
            --with-zlib=/lib            \
            --with-png=/usr/lib         \
            --with-jpeg                 \
            --with-libiconv=/usr        \
            --with-gd                   \
            --with-agg=/usr/lib         \
            --with-proj=/usr            \
            --with-threads              \
            --with-geos=/usr/bin/geos-config    \
            --with-ogr=/usr/bin/gdal-config     \
            --with-gdal=/usr/bin/gdal-config    \
            --with-tiff                         \
            --with-postgis=/usr/bin/pg_config   \
            --with-wcs                  \
            --with-wfsclient            \
            --with-wmsclient            \
            --with-sos                  \
            --with-curl-config=/usr/bin/curl-config     \
            --with-xml2-config=/usr/bin/xml2-config     \
            --with-httpd=/usr/sbin/httpd        \
            --with-warnings                     \
            --with-php=/usr/include/php         \
 Configure Report returned:
 MapServer is now configured for
  -------------- Compiler Info -------------
  C compiler:                gcc -g -O2 -fPIC -Wall
  C++ compiler:              g++ -g -O2 -fPIC -Wall
  Debug:                     -g  -DNEED_NONBLOCKING_STDERR
  Generic NINT:
  -------------- Renderer Settings ---------
  zlib support:              -DUSE_ZLIB
  png support:
  palette rgba png support:
  jpeg support:              -DUSE_JPEG
  iconv support:             -DUSE_ICONV
  AGG support:
  AGG Freetype support:
  Ming(flash) support:
  PDFLib support:
  -------------- Support Libraries ---------
  Proj.4 support:
  Libxml2 support:
  FriBidi support:
  Curl support:
  FastCGI support:
  Threading support:
  GEOS support:
  -------------- Data Format Drivers -------
  native tiff support:       -DUSE_TIFF
  PostGIS support:
  EPPL7 support:             -DUSE_EPPL
  ArcSDE support:
  OGR support:
  GDAL support:
  Oracle Spatial support:
  -------------- OGC Services --------------
  WMS Server:
  WMS Client:
  WFS Server:
  WFS Client:
  WCS Server:
  SOS Server:
  -------------- MapScript -----------------
  PHP MapScript:             no
 Error Messages from configure:
 ./myconfigure.sh: line 8: --with-gd: command not found
 ./myconfigure.sh: line 23: --with-httpd=/usr/sbin/httpd: No such file
 or directory
 ./myconfigure.sh: line 25: --with-php=/usr/include/php: No such file
 or directory
