[mapserver-users] Changing to Layers.WMS from Layers.Mapserver
Paul Curran
paul_everton at hotmail.com
Mon Jul 20 09:18:02 EDT 2009
Thanks for your response Jeff,
Ive read the document you suggested (http://www.mapserver.org/ogc/wms_server.html ) however i am still experiencing the same problem.
As the document suggests i have set a projection and then added the folowing to WEB section of my mapfile
METADATA
"wms_title" "UK1"
"wcs_onlineresource" http://127.0.0.1/cgi-bin/mapserv?map=wms.map&
"wms_srs" "EPSG:32119 EPSG:4326"
END
*Note 'wcs_onlinesresource' as my layer is a Raster
then wihtin the layer i have olny added "wms_title" "UK1" wihtin METADATA.
However i still get the error message "msWMSLoadGetMapParams(): WMS Server Error message " i have also looked throught the error documentation however i cannot find anything.
Any help appreciatted thanks
> Date: Fri, 17 Jul 2009 11:00:07 -0300
> From: jmckenna at gatewaygeomatics.com
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Changing to Layers.WMS from Layers.Mapserver - Error 'msWMSLoadGetMapParams(): WMS '
> Paul Curran wrote:
> > Ive implemented your changes but im still getting the
> > msWMSLoadGetMapParams(): WMS Server Error message repeatedly thorughout
> > the open layers map window.
> > My map file now looks like this (i have hihglighted your changes in
> > bold), do you think i have put them in correclty?
> Paul,
> If you are trying to serve your mapfile through WMS then you should
> follow this document: http://www.mapserver.org/ogc/wms_server.html
> Also, you should read the following page on MapServer projection use:
> http://www.mapserver.org/mapfile/projection.html
> -jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
_________________________________________________________________
With Windows Live, you can organise, edit, and share your photos.
http://clk.atdmt.com/UKM/go/134665338/direct/01/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090720/dbc3a1aa/attachment.html
