[mapserver-users] Shapefile with first FID = 0 not showing..
Michelle Douvil mrdouville at shaw.ca
Mon Jul 20 13:35:48 EDT 2009
Hi Jeff, thanks for the quick reply.. I haven't tried the shp2img..
My tests are through WMS only..
Jeff McKenna wrote:
> Douville, Michelle R ILMB:EX wrote:
>> Hello List,
>> I am currently using Mapserver 5.2 on Windows Server 2003.
>> (<!-- MapServer version 5.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI
>> SUPPORTS=THREADS INPUT=JPEG INPUT=SDE INPUT=ORACLESPATIAL INPUT=OGR
>> INPUT=GDAL INPUT=SHAPEFILE -->)
>> We have just observed,  that when we publish a shapefile that has two
>> features..
>> With FID = 0 and FID =1, it only displays the feature with FID = 1..
>> (for other Shapefiles it is all features greater than 0 only)
>> For some reason it seems to skip the feature if FID = 0
>> Has anyone else come across this before?
>> Is there a work around? (Other than editing the Shapefile),
>> Many thanks,
> Hello Michelle,
> I have never seen your issue before.  Test your mapfile with a shp2img
> command - does your problem still occur (in the resulting map image)?
> Or are you saying that this only occurs when you consume your mapfile
> through a WMS client?
> -jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Shapefile-with-first-FID-%3D-0-not-showing..-tp3289974p3290374.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
