[mapserver-users] Shapefile with first FID = 0 not showing..
Michelle Douvil
mrdouville at shaw.ca
Mon Jul 20 15:04:36 EDT 2009
Results of OGRINFO..
E:\apps_data\mapserverutils>ogrinfo -so E:\inetpub\wwwroot\imf\upload
INFO: Open of `E:\inetpub\wwwroot\imf\upload'
using driver `ESRI Shapefile' successful.
1: shp32973 (Polygon)
E:\apps_data\mapserverutils>ogrinfo -summary
E:\inetpub\wwwroot\imf\upload\shp32
973.shp shp32973
INFO: Open of `E:\inetpub\wwwroot\imf\upload\shp32973.shp'
Layer name: shp32973
Geometry: Polygon
Feature Count: 2
Extent: (827805.053191, 1185370.191489) - (1117390.585106, 1512564.234043)
Layer SRS WKT:
PROJCS["Albers Conical Equal Area",
GEOGCS["GCS_North_American_1983",
DATUM["North_American_Datum_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Albers_Conic_Equal_Area"],
PARAMETER["False_Easting",1000000.0],
PARAMETER["False_Northing",0.0],
PARAMETER["longitude_of_center",-126.0],
PARAMETER["Standard_Parallel_1",50.0],
PARAMETER["Standard_Parallel_2",58.5],
PARAMETER["latitude_of_center",45.0],
UNIT["Meter",1.0]]
IMF_ID: Integer (10.0)
E:\apps_data\mapserverutils>ogrinfo -ro
hp shp32973 -q
OGRFeature(shp32973):0
IMF_ID (Integer) = 0
POLYGON ((827805.053 1512564.234,1029010.585 1512564.234,1029010.585
1379054.0
21,827805.053 1379054.021,827805.053 1512564.234))
OGRFeature(shp32973):1
IMF_ID (Integer) = 1
POLYGON ((918065.479 1330162.957,1117390.585 1330162.957,1117390.585
1185370.1
91,918065.479 1185370.191,918065.479 1330162.957))
View this message in context: http://n2.nabble.com/Shapefile-with-first-FID-%3D-0-not-showing..-tp3289974p3290900.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
