[mapserver-users] Querymap
Steve Lime
Steve.Lime at dnr.state.mn.us
Fri Jul 24 23:26:09 EDT 2009
Hi Daniel: Sadly, no. It's primarily because there's only one querymap for potentially
all the layers so symbolization could become quite complex as different layers are processed.
A better solution is to store a selection style with each layer. Depending on your application
you might be able to work around this limitation using dynamic expressions. For example:
# selected feature layer
LAYER
NAME 'selected'
LABELITEM 'keyfield'
CLASS
EXPRESSION '%keyvalue%'
...styles to draw the feature in a selected manner...
METADATA
keyvalue_validation_pattern 'some regex to make sure the keyvalue is of the proper form'
END
END
END
Then if using the CGI you could call MapServer with a primary key from the selected
feature, e.g.:
/cgi-bin/mapserv?map=...&layer=selected&keyvalue=1234
If your app knows stuff about the selected feature (either as part of a template presentation or
perhaps the query was done via ajax) then this works nicely.
Steve
>>> Daniel Degasperi <daniel.degasperi at r3-gis.com> 07/23/09 3:42 AM >>>
Hello MapServer Users,
I've been using the Querymap-Feature of MapServer. As I understand the
objects are highlighted by changing the color. It would be very nice to
have the possibility to define other style-properties like SIZE,
OUTLINECOLOR, etc. Is this possible?
Best regards
Daniel Degasperi
Daniel Degasperi
Software Developer
R3 GIS Srl
Via Johann Kravogl 2
I-39010 Merano - Sinigo (BZ)
Tel. +39 0473 494949
Fax. +39 0473 069902
Web http://www.r3-gis.com
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
