[mapserver-users] Applying a hatch over a line layer
Adrian Popa
adrian_gh.popa at romtelecom.ro
Mon Jul 27 07:44:31 EDT 2009
Hello Thomas,
Thank you for your reply. I tried your solution and it draws a dashed
line paralel to my feature (on each side because the symbol is thicker).
This is nice, but I was wondering if it's possible to draw the lines at
an angle relative to my feature, thus created the "hatch" effect.
If this is not possible with a simple symbol - would it be possible with
a graphical symbol (picture)? And if yes, should I expect a high
performance penalty?
Thanks again,
Adrian
Thomas Bonfort wrote:
> hi,
> hatches only apply to polygon layers.
> what you are probably looking for is the PATTERN keyword:
> symbol
> type simple
> pattern 2 2 end
> name "dashes"
> end
> regards,
> thomas
> www.camptocamp.com
> +33 4 79 26 57 97
> On Mon, Jul 27, 2009 at 11:37, Adrian Popa<adrian_gh.popa at romtelecom.ro> wrote:
>> Hello,
>> I'm trying to apply a hatch over a line segment, but it doesn't seem to
>> work.
>> My symbol definition is:
>> SYMBOL NAME 'hatch'
>> TYPE HATCH END
>> My layer definition is:
>> LAYER
>> TYPE LINE
>> CLASS
>> NAME "Test"
>> EXPRESSION ( "[flag]" eq "1")
>> STYLE SYMBOL 'hatch'
>> ANGLE 45 SIZE 3 #spacing between
>> lines
>> WIDTH 4 #width of each line color "#000000"
>> END style
>> color "#fff94d" width 2
>> antialias true end
>> END
>> END
>> The behavior is the following: mapserver draws the lines using the second
>> style (a yellowish color), but doesn't draw a hatch over my line.
>> I've tried with the hatch symbol after the style definition, but it still
>> doesn't work. The hatch worked for POLYGON layers just fine.
>> Is there any way I can use it for LINE data?
>> Thanks,
>> Adrian
>> P.S. I'm using mapserver 5.4.1
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090727/462d97f5/attachment.html
