[mapserver-users] Applying a hatch over a line layer
Thomas Bonfort
thomas.bonfort at camptocamp.com
Mon Jul 27 08:00:59 EDT 2009
yes, you can definitely do that with an image symbol, although that
won't be very flexible if you want to change the width.
another solution would be with a vector symbol.
in both cases, you'll have to add a negative GAP to your symbol definition.
cheers,
thomas
www.camptocamp.com
+33 4 79 26 57 97
On Mon, Jul 27, 2009 at 13:47, Adrian Popa<adrian_gh.popa at romtelecom.ro> wrote:
> ...Or, to be more clear, I would like to give my lines a "striped" look - I
> don't know if there's an easier way to do it than using a symbol...
> Thanks.
> Adrian Popa wrote:
> Hello Thomas,
> Thank you for your reply. I tried your solution and it draws a dashed line
> paralel to my feature (on each side because the symbol is thicker). This is
> nice, but I was wondering if it's possible to draw the lines at an angle
> relative to my feature, thus created the "hatch" effect.
> If this is not possible with a simple symbol - would it be possible with a
> graphical symbol (picture)? And if yes, should I expect a high performance
> penalty?
> Thanks again,
> Adrian
> Thomas Bonfort wrote:
> hi,
> hatches only apply to polygon layers.
> what you are probably looking for is the PATTERN keyword:
> symbol
> type simple
> pattern 2 2 end
> name "dashes"
> end
> regards,
> thomas
> www.camptocamp.com
> +33 4 79 26 57 97
> On Mon, Jul 27, 2009 at 11:37, Adrian Popa<adrian_gh.popa at romtelecom.ro>
> wrote:
> Hello,
> I'm trying to apply a hatch over a line segment, but it doesn't seem to
> work.
> My symbol definition is:
> SYMBOL NAME 'hatch'
> TYPE HATCH END
> My layer definition is:
> LAYER
> TYPE LINE
> CLASS
> NAME "Test"
> EXPRESSION ( "[flag]" eq "1")
> STYLE SYMBOL 'hatch'
> ANGLE 45 SIZE 3 #spacing between
> lines
> WIDTH 4 #width of each line color "#000000"
> END style
> color "#fff94d" width 2
> antialias true end
> END
> END
> The behavior is the following: mapserver draws the lines using the second
> style (a yellowish color), but doesn't draw a hatch over my line.
> I've tried with the hatch symbol after the style definition, but it still
> doesn't work. The hatch worked for POLYGON layers just fine.
> Is there any way I can use it for LINE data?
> Thanks,
> Adrian
> P.S. I'm using mapserver 5.4.1
> mapserver-users at lists.osgeo.org
