[mapserver-users] distance between line and a given
point usingmapscript
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Jul 27 23:54:26 EDT 2009
There are lots of samples that show you how to loop through a set of search
results. There's a getNumResults() method for layer objects and then a getResult()
method to retrieve each one individually.
Steve
>>> Mark Brooks <mark_brooks at ncsu.edu> 07/27/09 9:50 AM >>>
Steve,
This is a huge help. The only thing I had not figured out was the
'toleranceunits' and 'tolerance' fields. I appreciate your help!
I intend to add many, possible hundreds, lines to a layer. Then query
it with a given reference point. How do I get the number of results and
then loop through each one?
Best Regards,
Mark
Steve Lime wrote:
>> How do I query a layer with one or more line features to find all
>> features with X miles of a given point?
> Your line layer should like so:
> LAYER
> NAME 'lines'
> TYPE LINE
> ...other junk...
> TEMPLATE 'dummy' # to be queryable
> TOLERANCEUNITS MILES
> TOLERANCE X
> END
> Then in mapscript you'd do a
> $my_layer->queryByPoint($my_point, MS_MULTIPLE, -1);
> The buffer parameter is used to override a layer tolerance so setting to -1 tells
> the method to ignore it. If you do use it then it's given in the units of the layer
> being searched (before any projection).
> Does that help?
> Steve
>>>> Mark Brooks <mark_brooks at ncsu.edu> 07/24/09 3:26 PM >>>
> I'm trying to create several new line objects and then find the lines
> that are within x miles of a given point. (i.e., how far away a given
> point is from the track of a hurricane or the path of a ship). I'm
> having some difficulties and I hope someone can help.
> Here is how I'm approaching the problem in PHP:
> // Test array of points. This is used to make a line.
> $points[0]['lat'] = 35.5;
> $points[0]['lon'] = -78.8;
> $points[1]['lat'] = 36.5;
> $points[1]['lon'] = -79.8;
> $points[2]['lat'] = 37.5;
> $points[2]['lon'] = -80.1;
> // make new map object.
> $map = ms_newMapObj('mapdata/mymap.map');
> // Create new line
> $my_line = ms_newLineObj();
> // Loop through points, and add to the line
> while (list(,$coordinate)=each($points)){
> // Create new point object
> $my_point = ms_newpointObj();
> $my_point->setXY($coordinate['lon'],$coordinate['lat']);
> // Add point to line object
> $my_line->add($my_point);
> // Now create a new shape
> $my_shape = ms_newShapeObj(MS_SHAPE_LINE);
> $my_shape->add($my_line);
> // create new layer
> $my_layer = ms_newLayerObj($map);
> // set some fields for this new layer
> //$my_layer->set("units","miles"); // does not seem to work as expected
> // Create new class and add TEMPLATE. This is required for queries on
> the layer to work?
> $my_class = ms_newClassObj($my_layer);
> $my_class->set("template",'/home/www/html/query_template.html');
> // Add feature to the layer
> $my_layer->addFeature($my_shape);
> // Draw map. Query doesn't work if I don't do this now.
> $map->draw();
> // Make a new point object that will be our ref point
> // to check how far away the line is from this point.
> $my_point->setXY(-82,36); // lon, lat
> // Run a point query on the line object layer; layer must have a class
> with a LAYER TEMPLATE value
> // The third argument is the buffer tolerance. Default unit is pixels?
> Must figure out how to make miles or km.
> if ($my_layer->queryByPoint($my_point,MS_SINGLE,1)==MS_SUCCESS){
> $my_result = $my_layer->getResult(0); // Get the result
> $my_layer =
> $my_layer->getShape($my_result->tileindex,$my_result->shapeindex); //
> Get the shape
> mapserver-users at lists.osgeo.org
Mark Brooks
State Climate Office of North Carolina
Box 7236, NC State University
Raleigh, NC 27695-7236
Phone: 919.515.1446
Fax: 919.515.1441
