[mapserver-users] Impossible to draw SDO Geometries from
Oraclewhen SDO_GTYPE is 2007 and the interpretation is
2(connectivity by arcs : SDO_ELEM_INFO(1, 1003, 2, [...]) )
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Jul 30 11:22:27 EDT 2009
Does it matter if you're using GD vs. AGG? They have slightly different transformation routines... Could
you post a picture of how it's supposed to look?
Steve
>>> On 7/30/2009 at 9:38 AM, in message
<38FFFA96BE9C224893B3559563614BEA12CC45 at begemsrv01.sodiplan-begem.local>,
"Julien Collaer" <JC at sodiplan.be> wrote:
> Hello list,
> I'm using Mapserver CGI 5.0.2 (and i'v tried with the 5.4.x too) to render a
> layer from an Oracle Spatial database (SDO geometries).
> Everything is working fine except for some geometries : multipolygons with
> interpretation 2 (vertex connected by arcs).
> Here is an example of such geometry :
> MDSYS.SDO_GEOMETRY(2007,26273,null,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,2,11,100
> 3,2,21,1003,2),MDSYS.SDO_ORDINATE_ARRAY(83933,89879.010577196,83936.989422804
> ,89883,83933,89886.989422804,83929.010577196,89883,83933,89879.010577196,8334
> 5,89445.010577196,83348.989422804,89449,83345,89452.989422804,83341.010577196
> ,89449,83345,89445.010577196,82793,89490.010577196,82796.989422804,89494,8279
> 3,89497.989422804,82789.010577196,89494,82793,89490.010577196))
> The layer is rendered but no feature are displayed.
> The geomtries are correct (verified with the Oracle MapViewer).
> If someone knows a solution for this case it will be very useful...
> Thanks in advance,
> Julien Collaer
