[mapserver-users] SLD with Mapserver 5.4.2
Andrea Dessì nkjoep at gmail.com
Fri Jul 31 04:45:29 EDT 2009
Hi Michael,
Thank you for your answer :)
Now SLD is working i had a mistake with names references.
I have just another question: how is possible to "add" a style
using SLD without overriding the whole server style?
I explain what i want to do: I have a map served by MapServer, so a
mapfile with layers and styles. I want to add a style with "new"
characteristics (could be outline or overriding just the color of the text).
Thanks,
Andrea
2009/7/30 Michael Schulz <mschulz at webgis.de>
> Hi Andrea,
> to use SLD you won't need very special mapfile configuration. You
> should pay attention to setting the imgpath parameter of the web
> section correctly, i.e. accessible and writable by mapserver-cgi,
> since the sld's are stored there temporarily while/after downloading
> them from the specified URL. I am not aware of any other special
> configuration, but very helpful are the debugging outputs, that you
> can enable with the keyword DEBUG "on" at map or layer level. I find
> it most convenient to specify an errorfile path via CONFIG
> "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt" at map level.
> Be sure to set the SLD's NamedLayer Name tag value exactly the same as
> your mapfile's layer name you want to style.
> Cheers, Michael
> 2009/7/30 Andrea Dessì <nkjoep at gmail.com>:
> > Hi,
> > i've started using Mapserver few days ago and i cannot apply SLD styles.
> > i'm using  MapServer version 5.4.2
> > OUTPUT=GIF OUTPUT=PNG
> > OUTPUT=JPEG OUTPUT=WBMP
> > OUTPUT=SVG
> > SUPPORTS=PROJ
> > SUPPORTS=AGG
> > SUPPORTS=FREETYPE
> > SUPPORTS=ICONV
> > SUPPORTS=WMS_SERVER
> > SUPPORTS=WMS_CLIENT
> > SUPPORTS=WFS_SERVER
> > SUPPORTS=WFS_CLIENT
> > SUPPORTS=WCS_SERVER
> > SUPPORTS=FASTCGI
> > SUPPORTS=THREADS
> > SUPPORTS=GEOS
> > INPUT=EPPL7
> > INPUT=POSTGIS
> > INPUT=OGR
> > INPUT=GDAL
> > INPUT=SHAPEFILE
> > under Ubuntu 9.04.
> > I want to user mapserver as WMS Server and the apply SLD styles on the
> > fly... the common query is:
> > http://localhost/cgi-bin/wms?SERVICE=WMS&
> > VERSION=1.1.1&
> > REQUEST=GetMap&
> > BBOX=-74.012362,40.752314,-73.948216,40.791051&
> > SRS=EPSG:4326&
> > WIDTH=500&
> > HEIGHT=500&
> > LAYERS=myground,myroads&
> > FORMAT=image/gif&
> > TRANSPARENT=TRUE&
> > SLD=http://localhost/mysld.xml
> > But sld is not applying.
> > The question is: there are specific parameters for using SLD in mapfile?
> > I'm feeling a bit confused about this.
> > Thank You,
> > Andrea
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Aufwind durch Wissen!
> Qualifizierte Open Source Schulungen bei der
> http://www.foss-akademie.de/
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
> Schwimmbadstraße 2
> D-79100  Freiburg i. Br.
> Tel:  +49 (0)761 705798-102
> Tel:  +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090731/f1c3e07d/attachment-0001.html
