[mapserver-users] Impossible to draw SDO Geometries
fromOraclewhen SDO_GTYPE is 2007 and the interpretation
is2(connectivity by arcs : SDO_ELEM_INFO(1, 1003, 2, [...]) )
Pano Voudouris
pvoudouris at gaiocorp.com
Fri Jul 31 04:49:54 EDT 2009
Julien,
I know you said you verified the geometries by Mapviewer but have you tried
the sdo_validate layer routine? Just to be sure...
Example from the manual:
-- Is a layer valid? (First, create the result table.)
CREATE TABLE val_results (sdo_rowid ROWID, result varchar2(1000));
-- (Next statement must be on one command line.)
CALL
SDO_GEOM.VALIDATE_LAYER_WITH_CONTEXT('COLA_MARKETS','SHAPE','VAL_RESULTS');
Call completed.
SQL> SELECT * from val_results;
SDO_ROWID
RESULT
Rows Processed <12>
AAABXNAABAAAK+YAAC
13349 [Element <1>] [Ring <1>][Edge <1>][Edge <3>]
Cheers,
Pano
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Julien Collaer
Sent: 30 July 2009 18:38
To: Bob Basques; mapserver-users at lists.osgeo.org
Subject: RE : [mapserver-users] Impossible to draw SDO Geometries
fromOraclewhen SDO_GTYPE is 2007 and the interpretation is2(connectivity by
Hello Bob,
thanks for your fast response.
These geometries are generated by Oracle : SDO_Buffer function on
multipoints geometries.
When i look to the SDO_GEOM example,there are three geometries (polygons)
composed of five points with the first point being the same of the last one
MDSYS.SDO_GEOMETRY(2007,26273,null,
MDSYS.SDO_ELEM_INFO_ARRAY(
1,1003,2,
11,1003,2,
21,1003,2),
MDSYS.SDO_ORDINATE_ARRAY(
--Geom 1 :
83933, 89879.010577196,
83936.989422804, 89883,
83933, 89886.989422804,
83929.010577196, 89883,
--Geom 2 :
83345, 89445.010577196,
83348.989422804, 89449,
83345, 89452.989422804,
83341.010577196, 89449,
--Geom 3 :
82793, 89490.010577196,
82796.989422804, 89494,
82793, 89497.989422804,
82789.010577196, 89494,
So i suppose that the problem must be something else.
Other thing : If i change manually (but, of course, it's not a solution for
the production version) the interpretation of the vertex from 2 to 1 (arcs
to lines) Mapserver is able to draw the rectangles.
Thanks,
Julien Collaer
-------- Message d'origine--------
De: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Date: jeu. 30/07/2009 16:57
À: Julien Collaer
Objet : Re: [mapserver-users] Impossible to draw SDO Geometries
fromOraclewhen SDO_GTYPE is 2007 and the interpretation is 2(connectivity by
Julien,
Looking at the SDO description in the Oracle MAN for . . .
1003 or 2003 2
Polygon made up of a connected sequence of circular arcs that closes on
itself. The end point of the last arc is the same as the start point of the
first arc.
Each circular arc is described using three coordinates: the start point of
the arc, any point on the arc, and the end point of the arc. The coordinates
for a point designating the end of one arc and the start of the next arc are
not repeated. For example, five coordinates are used to describe a polygon
made up of two connected circular arcs. Points 1, 2, and 3 define the first
arc, and points 3, 4, and 5 define the second arc. The coordinates for
points 1 and 5 must be the same (tolerance is not considered), and point 3
is not repeated.
It looks like the first and last points need to be the same and your record
shows different points for the first and last entries. You may have one
extra point on the end as well (I think), or maybe you are just missing the
last point on the end . . .
bobb
>>> "Julien Collaer" <JC at sodiplan.be> wrote:
Hello list,
I'm using Mapserver CGI 5.0.2 (and i'v tried with the 5.4.x too) to render a
layer from an Oracle Spatial database (SDO geometries).
Everything is working fine except for some geometries : multipolygons with
interpretation 2 (vertex connected by arcs).
Here is an example of such geometry :
MDSYS.SDO_GEOMETRY(2007,26273,null,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,2,11,100
3,2,21,1003,2),
MDSYS.SDO_ORDINATE_ARRAY(83933,89879.010577196,
83936.989422804,89883,
83933,89886.989422804,
83929.010577196,89883,
83345,89445.010577196,
83348.989422804,89449,
83345,89452.989422804,
83341.010577196,89449,
82793,89490.010577196,
82796.989422804,89494,
82793,89497.989422804,
82789.010577196,89494,
82793,89490.010577196))
The layer is rendered but no feature are displayed.
The geomtries are correct (verified with the Oracle MapViewer).
If someone knows a solution for this case it will be very useful...
Thanks in advance,
Julien Collaer
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090731/4db914d9/attachment.html
