[mapserver-users] Non stoping generation
Nelson Branco nelson.branco at co.sapo.pt
Wed Jun 3 06:37:07 EDT 2009
Hi Alexandre,
the Web server I'am mentioning is the MapServer Web Server.
I can observe the mapserv process running by more than 5 minutes (of CPU
time at 100%).
So, that doesn't seem to be the problem.
Thanks any way.
Meantime, I isolate the problem even more, I find that the "similiar"
request direct to MapServer worked, the difference is that TileCache is
configured do add a extent of 20px to eliminate miss match tile junctions.
However, the same request with that extra size direct to MapServer also
run forever...
Here is the URLs:
    - Faling one with extent:
    http://127.0.0.1:8881/cgi-bin/mapserv.exe?map=mapfile.map
        &transparent=true
        &layers=mylayer
        &styles=
        &service=WMS
        &width=552
        &format=image%2Fpng
        &request=GetMap
        &height=552
        &srs=epsg%3A900913
        &version=1.1.1
&bbox=-916644.789907%2C5099560.83129%2C-916315.155222%2C5099890.46597
    - Successful without extent:
        &transparent=false
        &layers=mylayer
        &styles=
        &service=WMS
        &width=512
        &format=image%2Fpng
        &request=GetMap
        &height=512
        &srs=epsg%3A900913
        &version=1.1.1
&bbox=-916632.846621%2C5099572.77457%2C-916327.098508%2C5099878.52268
Any more ideas?
Nelson Branco
Alexandre Dube wrote:
> Hi,
> That looks like a TileCache problem. Try the TileCache mailing list.
> Do you use a MapServerLayer in your tilecache.cfg ? If so, use WMSLayer
> instead.
> Alexandre
> Nelson Branco wrote:
>> I have a problem generating a few images, tiles with TileCache, that
>> run “forever” until Web server timed out (after more than 5 minutes).
>> The tiles failing are a rare occurrence, 1 in a half million or so,
>> and all in zoom level with a resolution of 0.29858214168548585 in
>> epsg:900913 projection (very close zoom, the roads are about 50px wide).
>> Any idea to solve the problem or to help identifying it?
>> Thanks.
>> Nelson Branco
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
