[mapserver-users] Zoom Level Layer Changes
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Thu Jun 4 10:28:05 EDT 2009
Anything that would work with Fusion also? I did just try this setup and
as a result end up having multiple different scale layers showing up in
the layer control. While for the technical mapping people this isn't a
problem I need things to be super simple for non-technical/GIS users.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
From: Julien-Samuel Lacroix [mailto:jlacroix at mapgears.com]
Sent: Thursday, June 04, 2009 10:04 AM
To: Nolte, Tim
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Zoom Level Layer Changes
If you are not using MapScript, I think the easiest way is to add a
second coverage layer that is OFF by default and put a MINSCALE 1200000
in the first Coverage layer.
Julien
Nolte, Tim wrote:
> OK, wondering if anyone has encountered this situation, and what I'm
> trying to accomplish. I have two groups of layers "Propagations" and
> "Coverage". The "Coverage" layers are on by default when first viewing
> the initial extents, the "Propagations" layers are off by default. The
> "Propagations" layers have a min/max scale of:
> MINSCALE 0
> MAXSCALE 1200000
> The "Coverage" layers can be on at any scale. Now here is what I want
to
> accomplish. When the users first loads the map I still want the
> "Coverage" layers to be ON and when the user zooms to a scale of
1200000
> or below I want the "Coverage" layers turned off and the
"Propagations"
> layers turned on. Now here's the catch, I still want the user to be
able
> to turn the "Coverage" layers back on at a scale of 1200000 or less. I
> tried adding a "STATUS" option at the CLASS level which didn't really
> work. I'm not sure if the only way to accomplish something like this
is
> with duplicating the layer definitions with different scales and
status?
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
Mapgears
http://www.mapgears.com/
