[mapserver-users] WMS Overlay shift
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Jun 5 05:43:29 EDT 2009
It must be related somehow to projections, but could you please give us a bit more information? Do you have a PROJECTION block at MAP level and/or at LAYER level? What do you have in "wms_srs" element in METADATA?
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Frank Broniewski
> Lähetetty: 5. kesäkuuta 2009 10:44
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] WMS Overlay shift
> Hello list,
> I am debugging a problem with my WMS server. I am serving
> administrational boundaries in a national reference system
> for use in different applications.
> Just yesterday I noticed a shift of the WMS layer to the east
> when I overlay the WMS layer with the original shapefile in
> ArcGIS. The shift is approx. 29m and I have no clue where to
> start looking for a solution.
> There is only one projection in the mapfile, and I set the
> view in ArcGis to the same projection. I checked the
> projection definition in ArcGis already to see if there is
> some mismatch but I couldn't find any. So I am rather
> clueless where to start looking for the reason of the shift.
> I checked also in OpenJump to see wether this is an ESRI
> effect, but there is the same shift in OpenJump
> Any hints are welcome ...
> Frank
