[mapserver-users] labeling streets
Raivo Alla snaperski at gmail.com
Tue Jun 9 01:50:36 EDT 2009
Thank You,
so it should be, but somehow in my case it does not work properly.
When i have no declaration of MINFEATURESIZE, then the picture looks fine:
http://picasaweb.google.com/snaperski/Ort#5345194219497220482
But when I add MINFEATURESIZE AUTO, most labels just disappear, even
if they have enough space to fit in:
http://picasaweb.google.com/snaperski/Ort#5345195269825705586
And those labeled straight streets contain only one feature (line
feature) each - so the label should fit in decently.
Label is declared this way:
		LABEL
			TYPE truetype
			ANTIALIAS true
			FONT "arial"
			COLOR 240 240 240
			OUTLINECOLOR 52 52 52
			SIZE 9
			force false
			MINDISTANCE 250
			MINFEATURESIZE auto
			ANGLE follow
			POSITION cc
			BUFFER 1
		END
Changing FORCE or POSITION parameters didnt help either....
Raivo
On Mon, Jun 8, 2009 at 12:55 PM, Christy Nieman<cnieman at dmsolutions.ca> wrote:
> Hi,
> You could set MINFEATURESIZE to AUTO and then only the labels that fit on
> the lines should be drawn.
> Regards,
> Christy
> Raivo Alla wrote:
>> Hello!
>> I'm stuck in simple-looking problem, but the solution is just hiding
>> somewhere.
>> The question is: how I can label only those line features, whos label
>> does not run over the line like that:
>> http://picasaweb.google.com/snaperski/Ort#5344831130138846050
>> As street lengths are very different, I cant solve the problem by
>> setting suitable MINFEATURESIZE for
>> respective MINSCALE,MAXSCALE range.
>> All the best,
>> Raivo Alla
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
