[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error on IIS(5.1 and 6.0) ... Possible BUG?
Tamas Szekeres szekerest at gmail.com
Tue Jun 9 18:02:40 EDT 2009
Paul,
I've just tried with the latest 5.4 version and worked fine though I'm using
OGR/mapinfo.tab data source.
I suspect you may run into a problem related to the possible differences in
the security settings. Some files may not be accessible by the current user
executing mapserv.exe which may be "IUSR_[computername]" for the normal CGI
and "NT AUTHORITY/NETWORK SERVICE" for the fast cgi option by default.
Best regards,
Tamas
2009/6/9 Paul james <pauljame at gmail.com>
> Just one update in my tests...
> Using FASTCGI It worked FINE (mapserver 5.4)...
> I added a bug ticket : http://trac.osgeo.org/mapserver/ticket/3049
> Paul
> On Tue, Jun 2, 2009 at 10:12 AM, Paul james <pauljame at gmail.com> wrote:
>> Probably is a mapserver CGI bug...
>> Paul
>> On Sat, May 30, 2009 at 11:56 PM, Brian Fischer <bfischer at houstoneng.com>wrote:
>>>  Paul,
>>> Just to let you know you are not alone.  I am experiencing the same
>>> problem with MS4W 3.0 beta 1 and 2.  I’ve reported it as a bug to the MS4W
>>> project.  Here’s a link to the bug report
>>> http://bugzilla.maptools.org/show_bug.cgi?id=2043.   I haven’t heard
>>> anything back on a solution yet.  I’m not sure if this is a MapServer bug or
>>> a bug with the way the MS4W package was compiled.  It runs fine of Apache
>>> for me.
>>> Brian Fischer
>>> Houston Engineering, Inc.
>>> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
>>> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Paul james
>>> *Sent:* Friday, May 29, 2009 1:08 PM
>>> *To:* Steve Lime
>>> *Cc:* mapserver-users at lists.osgeo.org; Daniel Morissette
>>> *Subject:* Re: [mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI
>>> http://localhost/cgi-bin/mapserv.exe?map=C%3A%2Finetpub%2Fwwwroot%2FOpenlayer%2FFiles%2FMapserver%2FMap.map&mode=map&map_imagetype=png&mapext=-180+0+-90+90&imgext=-180+0+-90+90&map_size=256+256&imgx=128&imgy=128&imgxy=256+256
>>> Paul
>>> On Fri, May 29, 2009 at 3:01 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>
>>> wrote:
>>> What's the full URL submitted against the CGI?
>>> >>> On 5/29/2009 at 12:59 PM, in message
>>> <33fad6880905291059i5602a89q84d7673ddcfff511 at mail.gmail.com>, Paul
>>> james
>>> > 1 -  I tried with 1500,1400,1310,development version(1500) and ms4w
>>> beta...
>>> > 2 -  Ím using normal CGI
>>> > 3 - My tests are only with Postgis... Íll generate a shapefile to
>>> test
>>> > later ...
>>> > Paul
>>> > On Fri, May 29, 2009 at 2:27 PM, Tamas Szekeres <szekerest at gmail.com>
>>> wrote:
>>> >> Hi Paul,
>>> >> Did you experience the same with the release-1310 and release-1400
>>> >> versions? Did you experience the same with the development version?
>>> >> Are you using fastCGI or normal cgi?
>>> >> Is this just a PostGIS related problem or you get the same with a
>>> simple
>>> >> shapefile?
>>> >> Sorry for the bunch of the questions...
>>> >> Best regards,
>>> >> Tamas
>>> >> 2009/5/29 Paul james <pauljame at gmail.com>
>>> >>> Yes Daniel...  I deleted all previous files and put only 5.4
>>> files... My
>>> >>> mapscript application is working fine on 5.4...
>>> >>> But the CGI dont...
>>> >>> Tested on Windows XP (IIS 5.1) and Windows 2003(IIS 6.0)...
>>> >>> Paul
>>> >>> On Fri, May 29, 2009 at 12:56 PM, Daniel Morissette <
>>> >>> dmorissette at mapgears.com> wrote:
>>> >>>> Paul james wrote:
>>> >>>>> Hi Daniel...
>>> >>>>> I got the binaries from Tamas build :
>>> >>>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>>> >>>>> And from MS4W 3.0 beta2...
>>> >>>>> Same result with both...
>>> >>>>> That error you got is my fault... I took off the :
>>> >>>>> IMAGE "..\Map.png"
>>> >>>>> from REFERENCE definition when copy the code to email...
>>> >>>>> My application works fine with 5.2 binary in iis 5.1 and 6.0
>>> >>>>> Just replacing with 5.4 binary I got that 502 error...
>>> >>>> Hopefully you always make sure you update all DLLs as well when
>>> you
>>> >>>> "replace with 5.4 binary"? Even if the DLLs have the same names,
>>> if they
>>> >>>> come from different build environments or versions they may not
>>> be
>>> >>>> compatible and could cause the kind of crashes that you are
>>> experiencing.
>>> >>>> Daniel
>>> >>>> Daniel Morissette
>>> >>>> http://www.mapgears.com/
>>> >>> _______________________________________________
>>> >>> mapserver-users mailing list
>>> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090610/0fd06d86/attachment-0001.html
