[mapserver-users] Rendering order of objects in a layer
Dan Little
danlittle at yahoo.com
Wed Jun 10 12:08:54 EDT 2009
If you're already pulling from a view, you might want to consider three views:
interstates
highways
local roads
(or how ever you layer it)
Then create three separate layers for each one of the views.
----- Original Message ----
> From: David Nugent <davidn at datalinktech.com.au>
> To: mapserver-users at lists.osgeo.org
> Sent: Wednesday, June 10, 2009 8:41:48 AM
> Subject: [mapserver-users] Rendering order of objects in a layer
> Hello all,
> Is there any way in which the rendering order of objects in a layer can be
> determined by mapserver?
> For example, I want to ensure that major roads (highways, arterials) are
> rendered after local/minor/unimproved roads when all are rendered as a single
> layer; which tends to make joins between them look much nicer if the major roads
> are rendered first.
> This is for vector data coming from postgis, which ultimately results in
> executing the query on a view. I hesitate to fiddle with forcing index use here
> as I would think the gist queries on the geometry field would come into play.
> However, the results in the query seem to drop by chance regardless if the order
> of CLASS sections in the mapfile (which is what I would expect).
> Regards,
> David
