[mapserver-users] Ignoring top level settings
Alexandre.Laplante at statcan.gc.ca
Thu Jun 11 16:25:31 EDT 2009
I I've discovered that the base layer rendering as jpg was a problem with my openlayers, not mapserver. However, I still can't change my top-level projection or extent. Any help is greatly appreciated.
Thank you.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Alexandre.Laplante at statcan.gc.ca
Sent: June 8, 2009 9:35 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Ignoring top level settings
Hello list,
It seems as though my top level settings in my mapfile are being ignored. No matter what I put as projection, the output doesn't change (unless it's an invalid projection). Changing the values of EXTENT doesn't change anything either, as my map always starts zoomed out very far. I also have not been able to make my base layer output as anything other than jpg.
I have a feeling that this is related to an invalid /tmp/ location in the mapfile. I have not been able to write the location of the /tmp/ folder (it's on the root of my c: drive) in a way that mapserver will use it.
Apart from these things, everything works fine. I've been able to sort of counter-act the projection ignoring by telling mapserver that the layer's projection has lat_0=-49 when in fact, it is in epsg:43204 meaning lat_0=49.
I've attached my mapfile.
Thanks in advance,
Alexandre Laplante
Étudiant Co-op / Co-op Student
Division de l'Agriculture / Agriculture Division
Statistique Canada / Statistics Canada
170 Tunney's Pasture Driveway
Éd. Jean-Talon, 12è étage D1 / Jean-Talon Building, 12th floor D1
Ottawa, Ontario
<<alex.map>>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090611/d54348ff/attachment.html
