[mapserver-users] MS 5.4.1 Build problems on Windows
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jun 16 23:54:20 EDT 2009
Hi all,
This is my first time trying to build mapserver under Windows and it is
dying in the regex-0.12 source with the the errors below. Any thoughts
on how to resolved this?
Thanks,
-Steve W.
cl /nologo /Ox /MD /W3 /EHsc
-Ic:\projects\mapserver\..\gdwin32 -Ic
:\projects\mapserver\..\proj-4.6.1/src -Ic:\projects\mapserver\..\regex-0.12
-Ic:\projects\mapserver\..\postgresql-8.3.7/src/interfaces/libpq
-Ic:\project
s\mapserver\..\postgresql-8.3.7/src/include
-Ic:\projects\mapserver\..\z
lib-1.2.3 -Ic:\projects\mapserver\..\libpng-1.2.8 -DHAVE_STRING_H
-DREGEX_MA
LLOC -DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRLCAT -DNEED_STRRSTR
-DNEED_S
TRCASESTR -DUSE_POSTGIS -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_GD_PNG
-DUSE_GD_JP
EG -DUSE_GD_WBMP -DUSE_GD_GIF -DGD_HAS_GDIMAGEGIFPTR -DUSE_GD_FT
-DGD_HAS_GETBIT
MAPFONT -DGD_HAS_FTEX_XSHOW -DUSE_THREAD -DIGNORE_MISSING_DATA
-DUSE_GD_ANTIALIAS -DWIN32 -D_WIN32 /c
egex-0.12\regex.c /Foc:\projects\mapserver\..\regex-0.12\regex.obj
regex.c
[snip lots of warnings]
c:\projects\mapserver\..\regex-0.12\regex.c(4877) : warning C4996:
'errcode': Th
is name was supported during some Whidbey pre-releases. Instead, use the
standar
d name errno_t.
C:\Program Files\Microsoft Visual Studio
9.0\VC\INCLUDE\crtdefs.h(548) :
see declaration of 'errcode'
c:\projects\mapserver\..\regex-0.12\regex.c(4877) : error C2081: 'preg'
: name i
n formal parameter list illegal
'errbuf' : name
in formal parameter list illegal
'errbuf_size' :
name in formal parameter list illegal
c:\projects\mapserver\..\regex-0.12\regex.c(4878) : error C2055:
expected formal
parameter list, not a type list
c:\projects\mapserver\..\regex-0.12\regex.c(4878) : error C2082:
redefinition of
formal parameter 'errcode'
c:\projects\mapserver\..\regex-0.12\regex.c(4886) : warning C4996:
'errcode': Th
standar
d name errno_t.
c:\projects\mapserver\..\regex-0.12\regex.c(4886) : error C2059: syntax
error :
'type'
c:\projects\mapserver\..\regex-0.12\regex.c(4894) : error C2275:
'errcode' : ill
egal use of this type as an expression
c:\projects\mapserver\..\regex-0.12\regex.c(4911) : warning C4996:
'strcpy': Thi
s function or variable may be unsafe. Consider using strcpy_s instead.
To disabl
e deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
9.0\VC\BIN
\cl.EXE"' : return code '0x2'
Stop.
