[mapserver-users] LABEL problem using CGI...
Paul james
pauljame at gmail.com
Wed Jun 17 09:19:57 EDT 2009
Thanks!
Paul
On Wed, Jun 17, 2009 at 10:01 AM, David Nugent
<davidn at datalinktech.com.au>wrote:
> On Wed, 17 Jun 2009 22:31:50 +1000, Paul james <pauljame at gmail.com> wrote:
> You are right...
>> It is Tiled (using OL)...
>> In that case, How can I "fix" that effect?
> This should be in an FAQ :-) It has been answered at least 4 times here in
> the last couple months...
> Add
> PROCESSING "LABEL_NO_CLIP=ON"
> to your LAYER.
> YYMV, but I've noticed a side-effect of using this that I've been unable to
> quantify. However it does stop the repetition of labels at the boundaries
> so it solves your problem.
> For me it seems to create another problem - clipping of labels at (meta)
> tile
> boundaries regardless what I'm setting LABELCACHE_MAP_EDGE_BUFFER to in the
> mapscript that renders the tiles. I made my metatiles larger to reduce this
> effect but have been meaning to try again with PARTIALS TRUE and not
> setting
> LABELCACHE_MAP_EDGE_BUFFER, which "in theory" should work.
> Regards,
> David
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090617/c720b9ba/attachment.html
