[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
Tamas Szekeres szekerest at gmail.com
Thu Jun 18 18:27:52 EDT 2009
I've set it up (Win2003) but didn't crash, though I get blank images in cgi
mode.
http://vbkto.dyndns.org:1280/cgi-bin4/mapserv.exe?map=E
:\tests\TestCGI\map.map&mode=map
shp2img produces correct image however. I'm a bit uncertain whether the 2
problems are the same but I'll look into this one in more detail shortly.
Tamas
2009/6/18 stela anders <stelaanders at gmail.com>
> Hi guys!
> I got that binary now :
> http://vbkto.dyndns.org:1280/sdk/release-1500-gdal-mapserver.zip
> Same error Tamas...
> System : Windows XP / IIS 5.1
> Using Postgis as datasourse...
> I made a package with :
> - Mapfile
> - Postgis data
> - Html
> You only need OL js to tryout...
> Or you can try typing :
> http://localhost/cgi-binx/mapserv.exe?map=map.map
> The error is :
> CGI Error
> The specified CGI application misbehaved by not returning a complete set of
> HTTP headers. The headers it did return are:
> Using version 5.2.2 all works fine...
> Stela
> 2009/6/18 Tamas Szekeres <szekerest at gmail.com>
> Hi,
>> Some of the guys reported issues with mapserver 5.4+ in normal CGI mode
>> (FastCGI was reported ok) but I couldn't reproduce it myself so it would be
>> helpful if someone could describe the steps (and provide mapfiles/sample
>> data) to check it out.
>> You could also test with the binaries provided from here which appears to
>> be working ok.
>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>> Best regards,
>> Tamas
>>>   Hey guys !
>>> That´s my first message here... (I´m from Argentina, sorry about my bad
>>> English)
>>> Is there any bug on Mapserver 5.4 CGI ?
>>> We have a full application using Mapserver 5.2 CGI on Windowns 2003/IIS
>>> ... We tried to update to newest version 5.4 and got a CGI error ...
>>> Is there any FAQ to upgrade ? Or maybe is it a bug?
>>> Stela
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090619/f6376258/attachment.html
