[mapserver-users] error in opening mapfile
Suman Chatterjee schatterjee at addisontx.gov
Mon Jun 22 17:51:12 EDT 2009
Hi all!
I have just started with Mapserver. I have installed the Mapserver from
ms4w. The map server and Apache server is running. I have also
downloaded the Itasca application and copied in the htdocs folder under
Apache. But my problem is I am not able to see the map. It is generating
the error message :
msLoadMap(): Unable to access file. (/mapservdemo/workshop/itasca.map)
I have changed the required IMAGEPATH and IMAGEURL  and the hidden
variables  in the  index.html file which is shown below:
<html>
  <head>
   <title>MapServer Itasca Application</title>
    <script language="javascript">
        function configure() {
                    var template =
document.demo.template.options[document.demo.template.selectedIndex].val
ue;
        // EDIT THE NEXT 2 LINES TO MATCH YOUR SETUP
        var snippet = "IMAGEPATH 'c:/webdevdata/ms_tmp/'";
        snippet += " IMAGEURL '/ms_tmp/'";
       snippet += " TEMPLATE " + template;
      document.demo.map_web.value = snippet;
        if(template.indexOf("frame") != -1) document.demo.action =
"frames.html";
        if(template.indexOf("dhtml") != -1) document.demo.action =
"frames_dhtml.html";
    </script>
  </head>
 <body bgcolor="#FFFFFF">
  <center><h2>MapServer Itasca Application (ms v5.0)</h2></center>
    <p><hr><p>
    This demonstration application will take you through various levels
of complexity. Starting with a basic application that
    allows a user to pan/zoom and change layers we add:
    <ul>
   <li> dynamically configured scalebars
      <li> javascript-based panning
      <li> query results to a frame
      <li> and finally, a DHTML rubber-band zoom/query capabilty
    </ul>
    The base data is the old-reliable Itasca dataset that we know and
love...
 <!-- EDIT THE FORM ACTION -->
    <form name="demo" method="GET" action="/cgi-bin/mapserv.exe"
onSubmit="configure()">
     <input type="hidden" name="layer" value="lakespy2">
  <input type="hidden" name="layer" value="dlgstln2">
     <input type="hidden" name="zoomsize" value=2>
   <input type="hidden" name="map_web" value="">
 <!-- EDIT THESE HIDDEN VARIABLES -->
 <input type="hidden" name="map"
value="/mapservdemo/workshop/itasca.map">
     <input type="hidden" name="program" value="/cgi-bin/mapserv.exe">
   <input type="hidden" name="root" value="/mapservdemo/workshop">
    <select name="template" size="1">
  <option value="itasca_basic.html"> Basic Application
     <option value="itasca_adds_scalebar.html"> &nbsp;&nbsp;-- Adds
second scalebar
     <option value="itasca_adds_pan.html"> &nbsp;&nbsp;-- Adds pan
controls
       <option value="itasca_adds_frames.html"> &nbsp;&nbsp;-- Adds
frames
    <option value="itasca_adds_dhtml.html"> &nbsp;&nbsp;-- Adds dhtml
rubber-band box
     </select>
      <input type="submit" value="Initialize"></center>
</form>
  <p><hr>
   <table width="100%"><tr><td align="right">This site running MapServer
v. 5.0</td></tr></table>
 </body>
</html>
The itasca.map file is as below:
# Start of map file
MAP
  NAME ITASCA
  STATUS ON
  SIZE 600 600
  EXTENT 388107.634400379 5203120.88405952 500896.339019834
5310243.30613897
  UNITS METERS
  SHAPEPATH "C:\ms4w\Apache\htdocs\mapservdemo\workshop\data"
  IMAGECOLOR 255 255 255
  TEMPLATEPATTERN "itasca"
  IMAGETYPE PNG
  # Projection definition, consult the PROJ.4 documentation for
parameter discussion
  # PROJECTION
  #   "proj=utm"
  #   "ellps=GRS80"
  #   "zone=15"
  #   "north"
  #   "no_defs"
  #   OR:
  #   "init=epsg:26915"
  # END
  # Start of symbol definitions (we're only using a few)
  SYMBOL
    NAME 'circle'
    TYPE ELLIPSE
    POINTS 1 1 END
    FILLED TRUE
  END
  SYMBOL
    NAME 'star'
    TYPE VECTOR
    FILLED TRUE
    POINTS
      0 .375
      .35 .375
      .5 0
      .65 .375
      1 .375
      .75 .625
      .875 1
      .5 .75
      .125 1
      .25 .625
    END
  END
  # Start of web interface definition (including WMS enabling metadata)
  WEB
    HEADER templates/header.html
    TEMPLATE "set in index.html"
    FOOTER templates/footer.html
    MINSCALE 1000
    MAXSCALE 1550000
    IMAGEPATH "c:/webdevdata/ms_tmp"
    IMAGEURL "/ms_tmp/"
    METADATA
      WMS_TITLE "UMN MapServer Itasca Demo"
      WMS_ABSTRACT "This is a UMN MapServer application for Itasca
County located in north central Minnesota."
      WMS_ACCESSCONSTRAINTS "none"
      # change this value to match your setup
      WMS_ONLINERESOURCE
"http://localhost/mapservdemo/workshop/index.html"
      WMS_SRS "EPSG:26915"
    END
  END
  # Start of reference map
  REFERENCE
    IMAGE graphics/reference.png
    EXTENT 393234.393701263 5205405.16440722 495769.579718949
5307959.02579127
    SIZE 120 120
    STATUS ON
    MINBOXSIZE 5
    MAXBOXSIZE 100
    COLOR 255 0 0
    OUTLINECOLOR 0 0 0
    MARKERSIZE 8
    MARKER 'star'
  END
  # Start of legend
  LEGEND
    KEYSIZE 18 12
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
    STATUS ON
  END
  # Start of scalebar
  SCALEBAR
    IMAGECOLOR 0 0 0
    LABEL
      COLOR 255 255 255
      SIZE TINY
    END
    STYLE 1
    SIZE 100 2
    COLOR 255 255 255
    UNITS MILES
    INTERVALS 1
    TRANSPARENT TRUE
    STATUS ON
  END
  # Start of layer definitions
  LAYER
    NAME drgs
    TYPE RASTER
    STATUS OFF
    # OFFSITE 31
    OFFSITE 252 252 252
    CLASS
      NAME 'Digital Raster Graphic'
      KEYIMAGE graphics/drgs_keyimage.png
    END
    METADATA
      WMS_TITLE "USGS 1:250,000 Digital Raster Graphic"
      WMS_ABSTRACT "Hibbing and Bemidji quadrangles. See
http://deli.dnr.state.mn.us/metadata/full/drgncim1.html for more
information."
    END
    TILEINDEX drgidx
  END
  LAYER
    NAME ctybdpy2
    TYPE POLYGON
    STATUS DEFAULT
    DATA ctybdpy2
    # no need for a background IF the USGS quads are being drawn
    REQUIRES "![drgs]"
    CLASSITEM 'cty_name'
    CLASS
      EXPRESSION 'Itasca'
      STYLE
        OUTLINECOLOR 128 128 128
        COLOR 225 225 185
      END
    END
    CLASS # every other county in the state
      EXPRESSION /./
       STYLE
        COLOR 255 255 255
      END
    END
    METADATA
      WMS_TITLE "County Boundary"
      WMS_ABSTRACT "Itasca County boundary shapefile. See
http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html for more
information."
    END
  END
  LAYER
    NAME mcd90py2
    GROUP cities
    TYPE POLYGON
    DATA mcd90py2
    STATUS OFF
    CLASSITEM city_name
    CLASS
      NAME "Cities & Towns"
      EXPRESSION /./
      STYLE
        COLOR 255 225 90
      END
      TEMPLATE "templates/mcd90py2.html"
    END
    HEADER "templates/mcd90py2_header.html"
    FOOTER "templates/mcd90py2_footer.html"
    DUMP TRUE # allow GML export
    METADATA
      WMS_TITLE "Minor Civil Divisions"
      WMS_ABSTRACT "Minor civil divisions for Itasca County (boundaries
only)."
    END
  END
  LAYER
    NAME twprgpy3
    TYPE POLYGON
    DATA twprgpy3
    STATUS OFF
    CLASS
      NAME 'Townships'
      STYLE
        SYMBOL 'circle'
        SIZE 2
        OUTLINECOLOR 181 181 145
      END
    END
    METADATA
      WMS_TITLE "Township Boundaries"
      WMS_ABSTRACT "Pulic Land Survey (PLS) township boundaries for
Itasca County. See
http://deli.dnr.state.mn.us/metadata/full/twprgne2.html for more
information."
    END
  END
  LAYER
    NAME lakespy2
    TYPE POLYGON
    STATUS OFF
    DATA lakespy2
    CLASS
      NAME 'Lakes & Rivers'
      TEMPLATE "templates/lakespy2.html"
      STYLE
        COLOR 49 117 185
      END
    END
    HEADER "templates/lakespy2_header.html"
    FOOTER "templates/lakespy2_footer.html"
    TOLERANCE 3
    METADATA
      WMS_TITLE "Lakes and Rivers"
      WMS_ABSTRACT "DLG lake and river polygons for Itasca County. See
http://deli.dnr.state.mn.us/metadata/full/dlglkpy2.html for more
information."
    END
  END # lakes
  LAYER
    NAME dlgstln2
    TYPE LINE
    STATUS OFF
    DATA dlgstln2
    CLASS
      NAME "Streams"
      TEMPLATE "templates/dlgstln2.html"
      STYLE
        COLOR 49 117 185
      END
    END
    HEADER "templates/dlgstln2_header.html"
    FOOTER "templates/dlgstln2_footer.html"
    TOLERANCE 5
    METADATA
      WMS_TITLE "Streams"
      WMS_ABSTRACT "DLG streams for Itasca County. See
http://deli.dnr.state.mn.us/metadata/full/dlgstln2.html for more
information."
    END
  END # streams
  LAYER
    NAME ctyrdln3
    GROUP roads
    MAXSCALE 300000
    STATUS OFF
    DATA ctyrdln3
    TYPE LINE
    CLASS
      STYLE
        COLOR 0 0 0
      END
    END
    METADATA
      WMS_TITLE "County Roads"
      WMS_ABSTRACT "County roads (lines only). Derived from MNDOT roads
layer, see http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for
more information."
    END
  END # county roads
  LAYER
    NAME ctyrdln3_anno
    GROUP roads
    MAXSCALE 300000
    STATUS OFF
    DATA ctyrdln3
    TYPE ANNOTATION
    LABELITEM "road_name"
    CLASS
      STYLE
        COLOR 255 255 255
        SYMBOL 'symbols/ctyhwy.png'
      END
      LABEL
        MINFEATURESIZE 40
        MINDISTANCE 150
        POSITION CC
        SIZE TINY
        COLOR 0 0 0
      END
    END
    METADATA
      WMS_ABSTRACT "County roads (shields only). Derived from MNDOT
roads layer, see http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html
for more information."
    END
  END # county road annotation
  LAYER
    NAME majrdln3
    GROUP roads
    MAXSCALE 600000
    STATUS OFF
    DATA majrdln3
    TYPE LINE
    CLASS
      NAME "Roads"
      STYLE
        COLOR 0 0 0
      END
    END
    METADATA
      WMS_TITLE "Highways"
      WMS_ABSTRACT "Highways- state, US and interstate (lines only).
Derived from MNDOT roads layer, see
http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for more
information."
    END
  END # highways
  LAYER
    NAME majrdln3_anno
    GROUP roads
    MAXSCALE 600000
    STATUS OFF
    DATA majrdln3
    TYPE ANNOTATION
    LABELITEM "road_num"
    CLASSITEM "road_class"
    CLASS
      EXPRESSION "3"
      STYLE
        COLOR 0 0 0 # dummy color
        SYMBOL 'symbols/sthwy.png'
      END
      LABEL
        MINFEATURESIZE 50
        MINDISTANCE 150
        POSITION CC
        SIZE TINY
        COLOR 0 0 0
      END
    END
    CLASS
      EXPRESSION "2"
      STYLE
        SYMBOL 'symbols/ushwy.png'
      END
      LABEL
        MINFEATURESIZE 50
        MINDISTANCE 150
        POSITION CC
        SIZE TINY
        COLOR 0 0 0
      END
    END
    CLASS
      EXPRESSION "1"
      STYLE
        SYMBOL 'symbols/interstate.png'
      END
      LABEL
        MINFEATURESIZE 50
        MINDISTANCE 150
        POSITION CC
        SIZE TINY
        COLOR 255 255 255
      END
    END
    METADATA
      WMS_ABSTRACT "Highways- state, US and interstate (shields only).
information."
    END
  END # highway annotation
  LAYER
    NAME airports
    TYPE POINT
    DATA airports
    STATUS OFF
    CLASS
      NAME 'Airports'
      STYLE
        COLOR 128 255 164
        SYMBOL 'circle'
        SIZE 7
      END
      TEMPLATE "templates/airports.html"
    END
    HEADER "templates/airports_header.html"
    FOOTER "templates/airports_footer.html"
    TOLERANCE 5
    METADATA
      WMS_TITLE "Airports"
      WMS_ABSTRACT "Airport runways for Itasca County."
    END
  END
  LAYER
    NAME mcd90py2_anno
    GROUP cities
    TYPE ANNOTATION
    DATA mcd90py2
    STATUS OFF
    LABELITEM "city_name"
    CLASSITEM "city_name"
    LABELMAXSCALE 500000
    CLASS
      EXPRESSION /./
      LABEL
        COLOR 0 0 0
        SHADOWCOLOR 218 218 218
        SHADOWSIZE 2 2
        TYPE BITMAP
        SIZE MEDIUM
        POSITION CC
        PARTIALS FALSE
        BUFFER 2
      END
    END
    METADATA
      WMS_ABSTRACT "Minor civil divisions for Itasca County (annotation
only)."
    END
  END
END # Map File
I have also changed my httpd.conf file  by including the following
lines:
Alias /ms_tmp/ "c:/webdevdata/ms_tmp/"
<Directory "c:/webdevdata/ms_tmp/">
  AllowOverride None
  Options Indexes FollowSymLinks Multiviews
  Order allow,deny
  Allow from all
</Directory>
But I am still receiving the same error.
When I am trying to display the Itasca.map file in the browser as below
http://127.0.0.1/cgi-bin/mapserv.exe?map="c:\ms4w\Apache\htdocs\mapservd
emo\workshop\itasca.map
<http://127.0.0.1/cgi-bin/mapserv.exe?map=%22c:\ms4w\Apache\htdocs\mapse
rvdemo\workshop\itasca.map> "
I am getting an error message
 msEvalRegex(): Regular expression error. String
("c:\ms4w\Apache\htdocs\mapservdemo\workshop\itasca.map") failed
expression test.
But I can open the map file in text form  in the browser without the
mapserver.
 I have no idea of what is going wrong? Any help in this regard is
welcome.
Thanks
Suman
This e-mail and any files or attachments transmitted with it contains Information that is confidential and privileged. This document may contain Protected Health Information (PHI) or other information that is intended only for the use of the individual(s) and entity(ies) to whom it is addressed. If you are the intended recipient, further disclosures are prohibited without proper authorization. If you are not the intended recipient, any disclosure, copying, printing, or use of this information is strictly prohibited and possibly a violation of federal or state law and regulations. If you have received this information in error, please delete it and notify Hamid Khaleghipour at 972-450-2868 immediately. Thank you.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090622/b94b707d/attachment-0001.html
