[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
stela anders
stelaanders at gmail.com
Tue Jun 23 10:04:14 EDT 2009
Great Tamas! Worked now...
You found the problem! Congrats!
Stella
2009/6/22 Tamas Szekeres <szekerest at gmail.com>
> Stela,
> By using my latest binaries I've found that mapserv.exe is hanging right
> after returning the image to the browser. This problem is possibly caused by
> some breaking changes in geos 3-1, since geos 3-0 seems to be working
> correctly. Would you test your application by using geos 3-0? I'd be curious
> to know whether this problem is the same as yours, or not.
> If you can't compile geos-3-0 then here is the dll compiled with MSVC2008.
> http://vbkto.dyndns.org:1280/tests/geos_c.zip
> Best regards,
> Tamas
> 2009/6/22 stela anders <stelaanders at gmail.com>
>> Log:
>> 13:45:38 inetinfo.exe:5544 OPEN C:\Mapserver\cg-binx\mapserv.exe SUCCESS Options:
>> Open Access: 001000A1
>> Open Access: 00100001
>> 13:45:38 inetinfo.exe:5544 QUERY
>> INFORMATION C:\Mapserver\cg-binx\mapserv.exe SUCCESS FileInternalInformation
>> 13:45:38 inetinfo.exe:5544 CLOSE C:\Mapserver\cg-binx\mapserv.exe SUCCESS
>> INFORMATION C:\Mapserver\cg-binx\mapserv.exe SUCCESS Attributes: A
>> INFORMATION C:\Mapserver\cg-binx\mapserv.exe SUCCESS Length: 33792
>> 13:45:38 inetinfo.exe:5544 DIRECTORY C:\Mapserver\cg-binx\ SUCCESS FileBothDirectoryInformation:
>> mapserv.exe
>> 13:45:38 inetinfo.exe:5544 OPEN C:\Mapserver\cg-binx\mapserv.exe.Manifest NOT
>> FOUND Options: Open Access: 001200A9
>> FOUND Options: Open Access: 00100001
>> 13:45:38 inetinfo.exe:5544 OPEN C:\Mapserver\cg-binx\mapserv.exe.Config NOT
>> 13:45:38 mapserv.exe:1012 QUERY
>> INFORMATION C:\Mapserver\cg-binx\mapserv.exe SUCCESS FileNameInformation
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\Prefetch\
>> MAPSERV.EXE-0B3170C2.pf <http://mapserv.exe-0b3170c2.pf/> NOT
>> FOUND Options: Open Access: Read
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\ SUCCESS Options: Open
>> Directory Access: 00100020
>> INFORMATION C:\Mapserver\cg-binx\libmap.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libmap.dll SUCCESS Options:
>> Open Access: 00100020
>> INFORMATION C:\Mapserver\cg-binx\libmap.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\libmap.dll SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libmap.dll.2.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libmap.dll.2.Config NOT
>> INFORMATION C:\Mapserver\cg-binx\zlib1.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\zlib1.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\zlib1.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\zlib1.dll SUCCESS
>> INFORMATION C:\Mapserver\cg-binx\mapserv.exe.Local\ NOT FOUND Attributes:
>> Error
>> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e SUCCESS Attributes:
>> D
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e SUCCESS Options:
>> Open Directory Access: 00100020
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCR90.dll SUCCESS Options:
>> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCR90.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCR90.dll SUCCESS
>> INFORMATION C:\Mapserver\cg-binx\proj.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\proj.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\proj.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\proj.dll SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\proj.dll.2.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\proj.dll.2.Config NOT
>> Error
>> D
>> INFORMATION C:\Mapserver\cg-binx\libxml2.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libxml2.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\libxml2.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\libxml2.dll SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libxml2.dll.2.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libxml2.dll.2.Config NOT
>> INFORMATION C:\Mapserver\cg-binx\WSOCK32.dll NOT FOUND Attributes: Error
>> INFORMATION C:\WINDOWS\system32\WSOCK32.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\WSOCK32.dll SUCCESS Options:
>> INFORMATION C:\WINDOWS\system32\WSOCK32.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\WSOCK32.dll SUCCESS
>> INFORMATION C:\Mapserver\cg-binx\WS2_32.dll NOT FOUND Attributes: Error
>> INFORMATION C:\WINDOWS\system32\WS2_32.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\WS2_32.dll SUCCESS Options:
>> INFORMATION C:\WINDOWS\system32\WS2_32.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\WS2_32.dll SUCCESS
>> INFORMATION C:\Mapserver\cg-binx\WS2HELP.dll NOT FOUND Attributes: Error
>> INFORMATION C:\WINDOWS\system32\WS2HELP.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\WS2HELP.dll SUCCESS Options:
>> INFORMATION C:\WINDOWS\system32\WS2HELP.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\WS2HELP.dll SUCCESS
>> INFORMATION C:\Mapserver\cg-binx\iconv.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\iconv.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\iconv.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\iconv.dll SUCCESS
>> Error
>> D
>> INFORMATION C:\Mapserver\cg-binx\libfcgi.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libfcgi.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\libfcgi.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\libfcgi.dll SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libfcgi.dll.2.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libfcgi.dll.2.Config NOT
>> Error
>> D
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCP90.dll SUCCESS Options:
>> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCP90.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCP90.dll SUCCESS
>> INFORMATION C:\Mapserver\cg-binx\pdflib.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\pdflib.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\pdflib.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\pdflib.dll SUCCESS
>> INFORMATION C:\Mapserver\cg-binx\fribidi.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\fribidi.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\fribidi.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\fribidi.dll SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\fribidi.dll.2.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\fribidi.dll.2.Config NOT
>> Error
>> D
>> INFORMATION C:\Mapserver\cg-binx\LIBPQ.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\LIBPQ.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\LIBPQ.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\LIBPQ.dll SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\LIBPQ.dll.2.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\LIBPQ.dll.2.Config NOT
>> Error
>> D
>> INFORMATION C:\Mapserver\cg-binx\SHFOLDER.dll NOT FOUND Attributes: Error
>> INFORMATION C:\WINDOWS\system32\SHFOLDER.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\SHFOLDER.dll SUCCESS Options:
>> INFORMATION C:\WINDOWS\system32\SHFOLDER.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\SHFOLDER.dll SUCCESS
>> INFORMATION C:\Mapserver\cg-binx\gdal17dev.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\gdal17dev.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\gdal17dev.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\gdal17dev.dll SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\gdal17dev.dll.2.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\gdal17dev.dll.2.Config NOT
>> INFORMATION C:\Mapserver\cg-binx\xerces-c_2_8.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\xerces-c_2_8.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\xerces-c_2_8.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\xerces-c_2_8.dll SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\xerces-c_2_8.dll.2.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\xerces-c_2_8.dll.2.Config NOT
>> Error
>> D
>> INFORMATION C:\Mapserver\cg-binx\libexpat.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libexpat.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\libexpat.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\libexpat.dll SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libexpat.dll.2.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libexpat.dll.2.Config NOT
>> Error
>> D
>> INFORMATION C:\Mapserver\cg-binx\ODBC32.dll NOT FOUND Attributes: Error
>> INFORMATION C:\WINDOWS\system32\ODBC32.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\ODBC32.dll SUCCESS Options:
>> INFORMATION C:\WINDOWS\system32\ODBC32.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\ODBC32.dll SUCCESS
>> INFORMATION C:\Mapserver\cg-binx\sqlite3.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\sqlite3.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\sqlite3.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\sqlite3.dll SUCCESS
>> INFORMATION C:\Mapserver\cg-binx\geos_c.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\geos_c.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\geos_c.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\geos_c.dll SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\geos_c.dll.2.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\geos_c.dll.2.Config NOT
>> Error
>> D
>> INFORMATION C:\Mapserver\cg-binx\libcurl.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libcurl.dll SUCCESS Options:
>> INFORMATION C:\Mapserver\cg-binx\libcurl.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\libcurl.dll SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libcurl.dll.2.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libcurl.dll.2.Config NOT
>> Error
>> D
>> Error
>> D
>> Error
>> D
>> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCR90.dll SUCCESS Attributes:
>> A
>> 13:45:38 mapserv.exe:1012 OPEN C:\ SUCCESS Options: Open Directory
>> Access: 00100001
>> 13:45:38 mapserv.exe:1012 DIRECTORY C:\ SUCCESS FileBothDirectoryInformation:
>> WINDOWS
>> 13:45:38 mapserv.exe:1012 CLOSE C:\ SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\ SUCCESS Options: Open
>> Directory Access: 00100001
>> 13:45:38 mapserv.exe:1012 DIRECTORY C:\WINDOWS\ SUCCESS FileBothDirectoryInformation:
>> WinSxS
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\ SUCCESS
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\ SUCCESS Options:
>> Open Directory Access: 00100001
>> 13:45:38 mapserv.exe:1012 DIRECTORY C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\ SUCCESS FileBothDirectoryInformation:
>> MSVCR90.dll
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\ SUCCESS
>> INFORMATION C:\WINDOWS\system32\IMM32.DLL SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\IMM32.DLL SUCCESS Options:
>> INFORMATION C:\WINDOWS\system32\IMM32.DLL SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\IMM32.DLL SUCCESS
>> INFORMATION C:\WINDOWS\system32\IMM32.DLL SUCCESS Length: 110080
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\COMCTL32.dll SUCCESS Options:
>> INFORMATION C:\WINDOWS\system32\COMCTL32.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\COMCTL32.dll SUCCESS
>> INFORMATION C:\WINDOWS\system32\COMCTL32.dll SUCCESS Length: 617472
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\COMCTL32.dll.124.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\COMCTL32.dll.124.Config NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\SHELL32.dll SUCCESS Options:
>> INFORMATION C:\WINDOWS\system32\SHELL32.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\SHELL32.dll SUCCESS
>> INFORMATION C:\WINDOWS\system32\SHELL32.dll SUCCESS Length: 8491008
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\SHELL32.dll.124.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\SHELL32.dll.124.Config NOT
>> Error
>> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83 SUCCESS Attributes:
>> D
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83 SUCCESS Options:
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll SUCCESS Options:
>> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll SUCCESS
>> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll SUCCESS Length:
>> 1054208
>> INFORMATION C:\WINDOWS\WindowsShell.Manifest SUCCESS Attributes: RHA
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WindowsShell.Manifest SUCCESS Options:
>> INFORMATION C:\WINDOWS\WindowsShell.Manifest SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WindowsShell.Manifest SUCCESS
>> INFORMATION C:\WINDOWS\WindowsShell.Manifest SUCCESS Length: 749
>> Open Access: Read
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WindowsShell.Config NOT
>> INFORMATION C:\WINDOWS\system32\odbcint.dll SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\odbcint.dll SUCCESS Options:
>> INFORMATION C:\WINDOWS\system32\odbcint.dll SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\odbcint.dll SUCCESS
>> INFORMATION C:\WINDOWS\system32\odbcint.dll SUCCESS Length: 98304
>> 13:45:38 mapserv.exe:1012 OPEN C:\MapServer\proj\nad \proj_def.dat PATH
>> NOT FOUND Options: Open Access: Read
>> NOT FOUND Options: Open Access: 00100001
>> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\map.map SUCCESS Options:
>> Open Access: Read
>> INFORMATION C:\Mapserver\cg-binx\ SUCCESS FileNameInformation
>> INFORMATION C:\Mapserver\cg-binx\map.map SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\map.map SUCCESS
>> 13:45:38 mapserv.exe:1012 READ
>> C:\Mapserver\cg-binx\map.map SUCCESS Offset: 0 Length: 8192
>> 13:45:38 mapserv.exe:1012 READ C:\Mapserver\cg-binx\map.map END OF
>> FILE Offset: 590 Length: 4096
>> FILE Offset: 590 Length: 8192
>> 13:45:38 mapserv.exe:1012 OPEN C:\MapServer\gdalplugins\ SUCCESS Options:
>> 13:45:38 mapserv.exe:1012 DIRECTORY C:\MapServer\gdalplugins\ SUCCESS FileBothDirectoryInformation:
>> 13:45:38 mapserv.exe:1012 DIRECTORY C:\MapServer\gdalplugins\ NO MORE
>> FILES FileBothDirectoryInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\MapServer\gdalplugins\ SUCCESS
>> INFORMATION C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS Attributes: A
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS Options:
>> INFORMATION C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS FileInternalInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS
>> INFORMATION C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS Length: 228872
>> INFORMATION C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS FileNameInformation
>> Access: 00100001
>> WINDOWS
>> system32
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\vsjitdebugger.exe.Manifest NOT
>> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\vsjitdebugger.exe.Config NOT
>> 13:45:38 vsjitdebugger.e:5636 QUERY
>> INFORMATION C:\Mapserver\cg-binx\mapserv.exe BUFFER
>> OVERFLOW FileNameInformation
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83 SUCCESS
>> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e SUCCESS
>> 13:45:38 svchost.exe:860 OPEN C:\WINDOWS\Prefetch\MAPSERV.EXE-0B3170C2.pf<http://mapserv.exe-0b3170c2.pf/> NOT
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090623/606d210b/attachment-0001.html
