[mapserver-users] WFS returning empty features
DeDuikertjes
DeDuikertjes at xs4all.nl
Wed Jun 24 09:25:33 EDT 2009
Roy, Jukka, List,
I've tried adding extents to each layer: no succes
I've
"gml_include_items" "all"
"gml_featureid" "geoidn"
in the layer metadata
MArco
Here is a snippet of the mapfile:
MAP
NAME "NL.IMRO.0026.SVBBU-0001"
IMAGETYPE png
UNITS METERS
EXTENT 155016 467631 156758 470080
PROJECTION
"init=epsg:28992"
END
WEB
METADATA
"ows_title" "NL.IMRO.0026.SVBBU-0001"
"wms_onlineresource"
"http://tercera-go.tercera-ro.nl/cgi-bin/mapserv?map=../html/plancheck_test/data/80.101.100.35_check/NL.IMRO.0026.SVBBU-0001/wkt/NL.IMRO.0026.SVBBU-0001.map&"
"wfs_onlineresource"
"wfs_srs" "EPSG:28992"
"wms_srs" "EPSG:28992"
END
END
LAYER
name "geoidNL.IMRO.0026.SVBBU-0001_vlak"
GROUP "geoidNL.IMRO.0026.SVBBU-0001"
PROJECTION
"init=epsg:28992"
END
METADATA
"ows_group_title" "geoidNL.IMRO.0026.SVBBU-0001"
"ows_title" "geoidNL.IMRO.0026.SVBBU-0001_vlak"
END
STATUS off
TYPE polygon
DUMP true
CONNECTIONTYPE postgis
CONNECTION "host=localhost user=tc_check dbname=80.101.100.35"
DATA 'tc_vlak_geometry from "NL.IMRO.0026.SVBBU-0001" using unique
geoidn using srid=28992'
FILTER "geoidn='geoidNL.IMRO.0026.SVBBU-0001'"
OPACITY 30
TEMPLATE "dummy.html"
CLASS
STYLE
COLOR 0 0 0
OUTLINECOLOR 255 0 0
END
END
END
Rahkonen Jukka schreef:
> Hi,
> Do you have something in "gml_include_items" in the layer metadata?
> -Jukka Rahkonen-
> DeDuikertjes wrote:
> Roy, List,
> i'm using MapServer version 5.1-dev
> I've set the map extent. I did not set layer extents. Is that necessary?
> MArco
> Roy Braam schreef:
>> What version of mapserver are you using? Have you set the map extent and layer extents?
>> Roy
>> _____
>> From: DeDuikertjes [mailto:DeDuikertjes at xs4all.nl]
>> To: mapserver-users at lists.osgeo.org
>> Sent: Wed, 24 Jun 2009 15:12:29 +0200
>> Subject: [mapserver-users] WFS returning empty features
>> Dear List,
>> I've mapserver all set up.
>> The mapfile is working and produces a nice and working WMS.
>> The WFS is giving me troubles.
>> It returns a valid capabilities document with no warnings
>> A getfeature request returns GML, with the bounds defined, but otherwise
>> with NO features.
>> This for a layer which draws perfectly well in the WMS.
>> uDig sees all colums (attributes) of the layer, but every column is empty.
>> I've not a clue what I am doing wrong.
>> any help greatly appreciated.
>> MArco
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
