[mapserver-users] installation debian lenny mapscript problem
julian andres montes galvis one1 at tutopia.com
Mon Mar 2 22:32:48 EST 2009
I found the solution
the first command with the  parameter  --with-php in the end , dont
work, the second  command  with the parameter --with-php in the start
works  fine
./configure --with-ogr --with-gdal --with-httpd=/usr/sbin/apache2
--enable-debug --with-curl-config=/usr/bin/curl-config --with-proj=/usr/
--with-tiff --with-gd=/usr/local/ --with-jpeg --with-freetype=/usr/
--with-threads --with-wcs --with-postgis  --with-libiconv=/usr
--with-libiconv=/usr --with-xml2-config=/usr/bin/xml2-config --with-sos
--with-wfsclient --with-wmsclient --with-wfs
-with-fastcgi=/usr/local/lib/ --with-agg -with-php=/usr/include/php5/
./configure -with-php=/usr/include/php5/ --with-ogr --with-gdal
--with-httpd=/usr/sbin/apache2 --enable-debug
--with-curl-config=/usr/bin/curl-config --with-proj=/usr/ --with-tiff
--with-gd=/usr/local/ --with-jpeg --with-freetype=/usr/ --with-threads
--with-wcs --with-postgis  --with-libiconv=/usr  --with-libiconv=/usr
--with-xml2-config=/usr/bin/xml2-config --with-sos --with-wfsclient
--with-wmsclient --with-wfs -with-fastcgi=/usr/local/lib/ --with-agg
Julian
julian andres montes galvis wrote:
> Hi ,
> my distro its a debian lenny, php5, apache 2.2.9, server x86, when I
> install mapserver 5.4.0-beta2(even 5.2) with the option --with-agg
> i have the error bellow, if erase this option, the installation it's
> succesfull.
> php_mapscript_util.c:32:22: error: maperror.h: No such file or directory
> php_mapscript_util.c: In function ‘_phpms_report_mapserver_error’:
> php_mapscript_util.c:44: error: ‘errorObj’ undeclared (first use in
> this function)
> php_mapscript_util.c:44: error: (Each undeclared identifier is
> reported only once
> php_mapscript_util.c:44: error: for each function it appears in.)
> php_mapscript_util.c:44: error: ‘ms_error’ undeclared (first use in
> this function)
> php_mapscript_util.c:46: warning: implicit declaration of function
> ‘msGetErrorObj’
> php_mapscript_util.c:48: error: ‘MS_NOERR’ undeclared (first use in
> this function)
> make[1]: *** [php_mapscript_util.o] Error 1
> Any Ideas ?
> thanks in advance
> Julian Montes
> pd: sorry but the english
> mapserver-users at lists.osgeo.org
