[mapserver-users] Image Quality - Image Preprocessing
Roger André
randre at gmail.com
Thu Mar 5 00:27:34 EST 2009
Hi Travis,
>From a purely subjective standpoint, I feel that the bilinear
resampling method works the best with aerial photo data. You can test
this using gdalwarp:
gdalwarp -ts <x_size> <y_size> -r <resampling_method> <infile> <outfile>
But before you resample all your data, you might try adding the
following processing directive to your imagery layer:
PROCESSING "RESAMPLE=BILINEAR"
You might find that this improves things enough.
Roger
On Wed, Mar 4, 2009 at 6:54 AM, Travis Kirstine
<traviskirstine at gmail.com> wrote:
> We are running mapserver connected to a tilecache delivering high
> resolution orthophoto to a google maps. The problem I am having is
> that we preprocess all our imagery using reduced resolutions at higher
> scales and full resolution at lower scales. In the past we have used
> gdal_merge with - ps 10 10 to merge tile into larger overalls and
> downsampling the resolution but we have found that the image quality
> was not adequate. I have been experimenting with gdalwarp using the
> different resampling methods with varied results. Is there any
> consensus on which resampling method provided with gdal provide the
> optimal results (from a viewing perspective) when downsampling imagery
> data?
> Travis K.
> Toronto, Canada
> "She knows there's no success like failure
> And that failure's no success at all."
> -Bob Dylan-
> mapserver-users at lists.osgeo.org
