[mapserver-users] 'errno: 2' on projection
julian andres montes galvis
one1 at tutopia.com
Thu Mar 5 08:07:23 EST 2009
try add
CONFIG "PROJ_LIB" "/usr/share/proj/"
kapilmanoj wrote:
> Hello wendall,
> I too facing the same problem. have you got solution for this problem?
> could you please help me out?
> Thanks,
> kapilmanoj
> Wendell Turner wrote:
>> On Mon, May 19, 2008 at 03:32:16PM -0700, Wendell Turner wrote:
>>> I'm trying to use the 'projection' tag in a map file, but it
>>> is not working, and would like help.
>>> I'm using Fedora 7, and there is a mapserver 4.10 in a yum
>>> repository, which pulls in proj as a dependency. However,
>>> when using the 'projection' tag, it gets
>>> msProcessProjection(): Projection library error. no system list, errno:
>>> 2
>>> (which seems to mean 'file not found')
>> As it turns out, other projections work.
>> I'm just trying to get the v4 tutorial working, which is
>> where the problem occurs. Any example that contains
>> PROJECTION
>> "init=epsg:4326"
>> END
>> gets the error msg. However, the file
>> /usr/local/share/proj/epsg contains an entry for 4326.
>> Q: why doe the example in the tutorial not work?
>> Q: how can it be fixed?
>> Thanks,
>> Wendell
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
