[mapserver-users] get connectiontyp via mapscript
Yewondwossen Assefa yassefa at dmsolutions.ca
Thu Mar 5 08:12:19 EST 2009
http://mapserver.org/mapscript/php/index.html (check Connection Types).
When using mapscript you should do your tests using the defined
constants (MS_SHAPEFILE, MS_POSTGIS ...).
  Note that the php defined constants reflect what is defined in
mapserver.h (MS_CONNECTION_TYPE enumeration)
Best Regards,
Sven Schroeter wrote:
> Hi all,
> I try to get the connectiontyp via mapscript, this works:
> $layer = $map->getLayerByName($qlayer);
> $contyp = $layer->connectiontype;
> I get back a "1" for shapefiles and a "6" for Postgis-layers.
> Where can I find the other types?
> Thanks
> Sven
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
