[mapserver-users] 500 Internal Server Error
Steve Lime Steve.Lime at dnr.state.mn.us
Thu Mar 5 12:38:54 EST 2009
Rui, what platform etc.. are you on?
>>> Rui Gomes <ruijgomes at gmail.com> 03/05/09 9:20 AM >>>
" Are you able to get into a shell?"
I do not think i can do that (or know how do that).
Thanks anyway
2009/3/5 Gregor at HostGIS <gregor at hostgis.com>:
>> And a few more question: what libraries i need to put in the server?
>> Where i can find some documentation about the libraries mapserver
>> need?
> A technique I find handy for debugging mapserver problems, a bit more useful
> than "Internal server error", is to go into the Unix shell and use shp2img.
> I'd use something similar to one of these:
>  shp2img -o test.png -m mapfile.map
>  shp2img -o test.png -m mapfile.map -d 999
>  shp2img -o test.png -m mapfile.map -l lakes,streets
> When that fails, it'll give you more information as to what went wrong. For
> example, it will give hints as to shapefiles being transferred in ASCII
> mode, or the TEMPDIR not being writable.
> Gregor Mosheh / Greg Allensworth    BS, A+, Network+, Security+, Server+
> System Administrator, Lead Programmer
> HostGIS development & hosting services, http://www.HostGIS.com/
> "Remember that no one cares if you can back up,
>  only if you can restore." - AMANDA
                                      Rui Gomes
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
